Zynthian UI User's Guide - Oram
Revision as of 07:04, 23 August 2024 by Riban (talk | contribs) (→‎UI Actions)
Ui push short icon.png Touching the topbar acts as a navigation operation which, by default opens a menu.
Topbar back button
Ui push short icon.png Touching the status bar may trigger a navigation action. See sections below for view specific behaviour.
Topbar Short press Show main menu
Chain Legend Short press Show control view
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
