Zynthian UI User's Guide - Oram
- Knob#4 is the select knob.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-push to select items.
- BACK Knob
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- back
- learn/shot
- select
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
Touching the topbar acts as a navigation operation which, by default opens a menu.
Touching the status bar may trigger a navigation action. See sections below for view specific behaviour.
1st row: Health & Load | ||
- knob#1
- knob#2
- knob#3
- knob#4
- layer
- back
- learn/shot
- select
Touch zone | Action | Behaviour |
Topbar | ![]() |
Show main menu |
Chain Legend | ![]() |
Show control view |
Show chain options |
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- Sequencer
- Tempo Settings
- Mixer Learn
- knob#4
- back
- select
Topbar back button | ![]() |
Previous view |
Mixer view |
Menu entry | ![]() |
Select menu action |
Show context menu for menu entry (if appropriate) |
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- back
- learn/shot
- select
- back
- learn/shot
- select
- knob#1 - knob#4
- knob#4
- knob#1 - knob#4
- layer
- back
- learn/shot
- select
- back
- select
- back
- learn/shot
- knob#4
- SEL
- knob#4
- SEL to select/check option.
- back
- select
- back
- select
- knob#4
- SEL
- back
- select
- replace the processor
- remove the processor
- knob#3
- knob#4
- knob#4
- SEL
- back
- learn/shot
- select
- back
- select
- load/unload drivers
- rename the device
- knob#4
- SEL
- knob#4
- SEL
- back
- select
- back
- select
6.3 Layering chains
- knob#4
- knob#3
- knob#2
- knob#1
- REC
- F4 adds a new empty loop
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
