Zynthian UI User's Guide - Oram
Revision as of 06:17, 23 August 2024 by Riban (talk | contribs) (Add mixer touch actions)
Ui push short icon.png Touching the topbar acts as a navigation operation which, by default opens a menu.
Topbar back button
Ui push short icon.png Touching the status bar may trigger a navigation action. See sections below for view specific behaviour.
Short press Topbar: Show main menu. Short press Legend: Show control view. Short press Legend: Show chain options.
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
