Zynthian UI User's Guide - Oram
Revision as of 08:14, 22 August 2024 by Riban (talk | contribs) (Hide push button section for touch only)
The simplest user interface is composed of a display with touch or mouse. A minimum display size of 5 inches and capacitive touch is strongly advised when this is the primary user input method. If using a smaller or resistive touch then a stylus is highly recommended. Zynthian UI can also be run head-less, accessing remotely with VNC.
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
