Zynthian UI User's Guide - Oram
Revision as of 21:28, 13 August 2024 by Jofemodo (talk | contribs) (→‎Presets)
If preset preload is enabled from admin options, the highlighted preset will be preload when MIDI note is received. This allows to pre-listen presets before selecting them. Please, note that most of times you need to play 2 notes to pre-listen the preset.
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
