Zynthian UI User's Guide - Oram
Revision as of 21:19, 13 August 2024 by Jofemodo (talk | contribs) (→‎Banks)
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
