Zynthian UI User's Guide - Oram
- Knob#4 is the select knob.
- ZS3 (sub-snapshots)
- #Snapshots|Snapshots
Zynsampler
Sooperlooper
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
1st row: Health & Load | ||
- knob#1
- knob#2
- knob#3
- knob#4
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- knob#4
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- 4 x controller widgets, dynamically assigned to the parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
- knob#1 - knob#4
- knob#4
- knob#4
- bold push to open preset options menu.
- SEL
- knob#4
- SEL to select/check option.
- knob#4
- bold push to open bank options menu.
- SEL
5.8 MIDI input/output
5.9 Key range & transpose
5.10 Snapshots
5.11 ZS3s (sub-snapshots)
5.12 Confirmation dialog
5.13 On-screen keyboard
5.14 Admin
6.3 Layering chains
- knob#4
- knob#3
- knob#2
- knob#1
The pattern editor has a custom ALT mode. For accessing it, simply push the ALT button and the arrow buttons will change its color to orange, allowing to quickly access undo/redo functions:
- REC
- F4 adds a new empty loop
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
