Zynthian UI User's Guide - Oram
- Knob#4 is the select knob.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-push to select items.
- BACK Knob
- Mixer
- ZS3 (SubSnapShots)
- Tempo settings / Tap-Tempo
- ZynPad (Scene)
- Pattern Editor
Zynsampler
Sooperlooper
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- back
- learn/shot
- select
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
1st row: Health & Load | ||
- knob#1
- knob#2
- knob#3
- knob#4
- layer
- back
- learn/shot
- select
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- Sequencer
- Tempo Settings
- Mixer Learn
- knob#4
- layer
- back
- learn/shot
- select
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- layer
- back
- learn/shot
- select
- back
- learn/shot
- select
- 4 x controller widgets, dynamically assigned to the parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.Depending of configuration options, the controller widgets could be layered at the four display corners (classic layout: top-left, down-left, top-right, down-right) or they could be all at right (V5 layout).
- knob#1 - knob#4
- knob#4
- layer
- back
- learn/shot
- select
- back
- select
- knob#4
- bold push to open preset options menu.
- SEL
- knob#4
- SEL to select/check option.
- back
- select
- bold-push to open the preset options menu.
- back
- select
- knob#4
- bold push to open bank options menu.
- SEL
- back
- select
- bold-push to open the bank options menu.
5.8 MIDI input/output
5.9 Key range & transpose
5.10 Snapshots
5.11 ZS3s (sub-snapshots)
5.12 Confirmation dialog
5.13 On-screen keyboard
5.14 Admin
6.3 Layering chains
- knob#4
- knob#3
- knob#2
- knob#1
The pattern editor has a custom ALT mode. For accessing it, simply push the ALT button and the arrow buttons will change its color to orange, allowing to quickly access undo/redo functions:
8.4 Tempo settings
- REC
- F4 adds a new empty loop
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
