Zynthian UI User's Guide - Oram
3.4 Using the push buttons
  • the primary view, when none of the button's views is shown
  • OPT/ADMIN
    • Options / Menu: Contextual. Click several times to reach the main menu.
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control
    • Preset/Bank
  • ZS3/SNAPSHOT
    • ZS3 (SubSnapShots)
  • METRONOME
    • Tempo settings / Tap-Tempo
  • PAD/STEP
    • ZynPad (Scene)
    • Pattern Editor
  • PAD/STEP => Long-push to access the Arranger view
Sooperlooper
Zynsampler
Sooperlooper
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
The V4 knobs (rotaries & switches) are the primary mechanism to navigate the UI. It's functionality is contextual, specially short and bold push actions. Long push actions are always global. The knobs' names used in this guide are the names printed in the official V4 aluminum case, from top to bottom and left to right:
UI Actions
5.2 Engine selection
5.3 Chain control
The chain control view allow accessing the chain's processors and its parameters. For instance, you can adjust the LFO frequency on a synth, the reverb's room size, the equalizer bands, etc. The default control view is composed of:
  • a list of controller pages, grouped by processor
  • 4 x controller widgets, dynamically assigned to the parameters of the selected page. These controller widgets are layered aside the 4 rotary encoders that can be used for modifying the value in real time.
UI Actions
    • short-push any knob to start MIDI-learning for the associated parameter. If wanted, a second push for global learning. Move a knob/fader in your MIDI controller to complete the learn. You can push BACK button to cancel at any moment.
  • knob#4 (select mode)
    • rotate to fast browse across controller pages
You can navigate the controller pages by using the UP/DOWN arrow buttons. You can change the controlled (active) chain by using the LEFT/RIGHT arrow buttons. To enter select mode and fast-browse controller pages by rotating knob#4, you must short-push the SEL button. Bold-pushing knob#4 doesn't work for this in V5.
  • LAYER
  • BACK
    • short-push (select mode) to exit from select mode.
    • short-push (midi learning) to cancel midi learning.
  • LEARN/SHOT
    • short-push any knob to start MIDI-learning. If wanted, a second push for global learning. Move a zynthian's knob to select the parameter. Then, move a knob/fader in your MIDI controller to complete the learn. You can push BACK button to cancel at any moment.
  • SELECT
    • rotate (select mode) Move across controller pages.
    • short-push to toggle select mode.
5.4 Chain options
5.5 MIDI input/output
5.6 Banks & Presets
5.7 Snapshots
5.8 ZS3s (sub-snapshots)
5.9 Confirmation dialog
5.10 On-screen keyboard
5.11 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
