Zynthian UI User's Guide - Oram
Revision as of 18:27, 8 August 2024 by Jofemodo (talk | contribs) (→‎Mixer)
3.4 Using the push buttons
  • the primary view, when none of the button's views is shown
  • OPT/ADMIN
    • Options / Menu: Contextual. Click several times to reach the main menu.
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control
    • Preset/Bank
  • ZS3/SNAPSHOT
    • ZS3 (SubSnapShots)
  • METRONOME
    • Tempo settings / Tap-Tempo
  • PAD/STEP
    • ZynPad (Scene)
    • Pattern Editor
  • PAD/STEP => Long-push to access the Arranger view
Sooperlooper
Zynsampler
Sooperlooper
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
UI Actions
5.3 Engine selection
  • Knob#1 - #4
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
