Zynthian UI User's Guide - Oram
3.4 Using the push buttons
For instance, if you are in the mixer view and short-push the OPT/ADMIN button, the Main menu will be opened. If you short-push it again, the Admin menu will be opened. Then, if you bold-push the MIX/LEVEL button, the Audio Levels view will be opened. You push "metronome" button and the Tempo settings view will be opened. If you tap-it several times, the tempo BPM will be changed, e.g. tap twice per second to set tempo to 120BPM.
  • OPT/ADMIN
    • Options / Menu: Contextual. Click several times to reach the main menu.
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control
    • Preset/Bank
  • ZS3/SNAPSHOT
    • ZS3 (SubSnapShots)
  • METRONOME
    • Tempo settings / Tap-Tempo
  • PAD/STEP
    • ZynPad (Scene)
    • Pattern Editor
The ALT button toggles the alternate function mode. When you click it, the ALT button and the buttons having an alternate function will change their default color from blue to purple or orange. ALT mode is contextual depending of the view. By default, transport and custom buttons (F1-F4) have alternate functions defined like this:
Sooperlooper
Zynsampler
Sooperlooper
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
  • SELECT Knob acts as the select knob.
UI Actions
5.3 Engine selection
  • Knob#1 - #4
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
