Zynthian UI User's Guide - Oram
Revision as of 12:59, 8 August 2024 by Riban (talk | contribs) (Fix accessibility alt captions)
3.4 Using the push buttons
For instance, if you are in the mixer view and short-push the OPT/ADMIN button, the Main menu will be opened. If you short-push it again, the Admin menu will be opened. Then, if you bold-push the MIX/LEVEL button, the Audio Levels view will be opened. You push "metronome" button and the Tempo settings view will be opened. If you tap-it several times, the tempo BPM will be changed, e.g. tap twice per second to set tempo to 120BPM.
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo options / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
The ALT button toggles the alternate function mode. When you click it, ALT button and buttons having an alternate function will change their default color from blue to purple or orange. Most of times, only transport and custom buttons (F1-F4) have alternate function:
But some views have custom ALT modes with specific functionality:
  • Pattern editor Use the arrow buttons to fast access Undo/Redo functionality.
  • Sooper Looper: Redefine the functionality of transport and F1-F4 buttons.
Pattern editor view
Zynsampler control view
SooperLooper control view
The control view of the sooperlooper processor have a customized ALT mode. When it's active, transport buttons and F1-F4 can be used to control sooperlooper specific functions like record, overdub, etc.
  • Up/Down arrow buttons:
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
  • SELECT Knob acts as the select knob.
  • solo: Solo flag. Push to toggle. This is a non-exclusive solo mode. When a chain has solo checked, all other chains without solo enabled will be muted, allowing auditioning of one or more chains.
  • mute: Mute flag. Push to toggle. When a chain is muted (it has "mute" checked), it will remain silent.
  • fader: Mixing volume for the associated chain. Drag up & down to modify the fader level. On the touchscreen you can drag multiple faders at once. Tap it for setting the active chain.
UI Actions
5.3 Engine selection
  • Knob#1 - #4
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
