Zynthian UI User's Guide - Oram
Revision as of 12:45, 8 August 2024 by Riban (talk | contribs) (Adds alt text for V4 mixer learn/shot.)
3.4 Using the push buttons
For instance, if you are in the mixer view and short-push the OPT/ADMIN button, the Main menu will be opened. If you short-push it again, the Admin menu will be opened. Then, if you bold-push the MIX/LEVEL button, the Audio Levels view will be opened. You push "metronome" button and the Tempo settings view will be opened. If you tap-it several times, the tempo BPM will be changed, e.g. tap twice per second to set tempo to 120BPM.
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo options / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
Pattern editor view
Zynsampler control view
  • Up/Down arrow buttons:
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
  • SELECT Knob acts as the select knob.
UI Actions
V5 mixer view encoder actions. Rotate knob 1 to change the volume of active chain, short push to solo the active chain. Rotate knob 2 to change the balance of the active chain, short push to mute the active chain. Rotate knob 3 to change the main volume, short push to open mixer's MIDI learning menu. Rotate knob 4 to change active chain selection, short push to open chain control view for active chain, bold push to open chain options for active chain.
V4 mixer view encoder actions. Rotate layer knob to change the volume of the active chain, short push to solo the active chain, bold push to open the main menu, long push to open the admin menu. Rotate back encoder to change balance of the active chain, short push to mute the active chain, bold push to open the zynpad view, long push to stop all notes and sounds. Rotate learn shot knob to change the main volume, short push to open the mixer's midi learning menu, bold push to open the ZS3 list, long push to open the snapshot list. Rotate select knob to change the active chain, short push to open the chain control for the active chain, bold push to open the chain options for the active chain, long push to turn the Zynthian off. It will ask to confirm.
5.3 Engine selection
  • Knob#1 - #4
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
