Zynthian UI User's Guide - Oram
Revision as of 12:06, 8 August 2024 by Jofemodo (talk | contribs) (→‎Mixer)
The barebones user interface is composed of a display with touch or mouse. A minimum display size of 5 inches and capacitive touch is strongly advised when this is the primary user input method.
  • Knob rotatation: You can rotate knobs, of course ;-)
  • Button/switch push: There are 3 types of push actions that can be performed, depending on how long you hold down the button, knob-switch or display widget.
  • Touch: Display touch or mouse actions.
These icons are used to indicate knob rotation and the three types of push actions throughout this guide:
Types of push actions
Ui knob rotate icon.png Knob Rotate Rotate the knob
3.4 Using the push buttons
For instance, if you are in the mixer view and short-push the OPT/ADMIN button, the Main menu will be opened. If you short-push it again, the Admin menu will be opened. Then, if you bold-push the MIX/LEVEL button, the Audio Levels view will be opened. You push "metronome" button and the Tempo settings view will be opened. If you tap-it several times, the tempo BPM will be changed, e.g. tap twice per second to set tempo to 120BPM.
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo options / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
Pattern editor view
Zynsampler control view
  • Up/Down arrow buttons:
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
      • Long => All Sounds Off
      • Short => Zynpad
      • Bold => Pattern Editor
      • Short/Bold => Arrow Up
      • Short/Bold => Arrow Down
3.5 Using the knobs
  • SELECT Knob acts as the select knob.
UI Actions
V5 mixer view encoder actions. Rotate knob 1 to change the volume of active chain, short push to solo the active chain. Rotate knob 2 to change the balance of the active chain, short push to mute the active chain. Rotate knob 3 to change the main volume, short push to open mixer's MIDI learning menu. Rotate knob 4 to change active chain selection, short push to open chain control view for active chain, bold push to open chain options for active chain.
5.3 Engine selection
  • Knob#1 - #4
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
