TESTING Zynthian UI Users Guide
Revision as of 14:32, 23 June 2024 by Riban (talk | contribs)
The Zynthian V5 physical user interface is composed, from left to right, of:
This rich interface allows simple navigation and reduces the number of "clicks", which improves workflow and makes it faster and more intuitive.
  • adjusting parameters
There are 3 types of push actions that can be performed, depending on how long you hold down the button, knob or screen:
1.1 The Title Bar
1.2 The Status Area
Let's see the details:
1.2.2 The Status Icons
2.1 Chains
Synth, MIDI & MIDI+Audio chains have a MIDI channel assigned. MIDI channels are not exclusive. You can assign the same MIDI channel to several chains. MIDI and MIDI+Audio chains can receive all MIDI channels.
In MIDI+Audio chains, all audio processors in the chain receive all the MIDI events on the assigned channel (this should be improved!).
Each chain receive MIDI input from selected devices (keyboards and other MIDI controllers). You can configure the MIDI input devices from the chain's option menu. Use short-push to enable / disable the devices and bold-push to change the input mode. All input devices are selected by default when creating a new chain.
  • ACTI: only the active chain receives all MIDI input from the device and all MIDI events are translated to the active chain's MIDI channel. This is the default mode.
  • MULTI: each chain receives MIDI from the input device using the controller's MIDI channel. No MIDI channel translation is done.
When using ACTI mode you don't need to worry about the MIDI channel your keyboard/controller is using. You change the instrument you play by changing the active chain in your Zynthian. You can change the active chain by simply rotating the select knob (#4) in the Mixer view or using the the left/right arrows.
On the other hand, MULTI mode allows receiving and managing separately every MIDI channel. Each MIDI controller will drive the chains assigned to the controller's MIDI channel. If you are using a MIDI controller that can sequence multiple tracks (Beatstep Pro, Keystep Pro, Novation Circuit, etc.) then you will generally want to use this mode.
3 Using the push buttons
3.1 Screen access buttons
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo screen / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
3.2 ALT button
3.3 Transport buttons
Pattern editor screen
Audio-player chain
3.4 Navigation buttons
  • Up/Down arrow buttons:
    • Browsing lists and menus.
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
3.5 Custom function buttons
Buttons
F1-F4
are considered to be customizable buttons, e.g. if you want direct access to other screens, etc. you may reconfigure these buttons using the webconf's wiring layout tab.
4 Using the knobs
4.1 General rule
  • Knob#1 - #4
4.3 Mixer
4.4 Scene (ZynPad)
4.5 Pattern
5 The UI Screens
6 Learning Pills
6.1 Basics
6.2 Sequencer
6.3 Mini-HowTos
7 Work In Progress
