Supported plug & play MIDI controllers
Revision as of 13:49, 30 July 2026 by Lfo (talk | contribs)
This section contain documentation for some of these controller drivers. There are two core driver functions which control the primary screens in the Zynthian UI:
  • Launcher mode (Zynpad): Launch patterns in the launcher grid interface (as with DAWs like Ableton or Logic)
  • Mixer mode (ZynMixer): Control chain levels, mutes and solo. Different devices may have some additional controls and functions.
There are also additional driver modes/functions depending on the device and driver:
  • SuperLooper Mode: Provides an interface to the native SuperLooper UI within Zynthian for looping live performance.
  • Sequencer Mode (ZynSeq): (Sequencer functionality for the device depends on the Zynthian version installed) Provides some degree of control over the sequencer or pattern editor.
Device Launcher mode (ZynPad) Mixer mode (ZynMixer) UI Navigation SuperLooper mode Sequencer mode (ZynSeq) Moder (chords/scales) Extra features / notes
Akai APC Key25 MK2
yes yes no no yes no Mixpad (default) controls Mixer + ZynPad; also Step Sequencer / pattern editor; Device mode controls the Zynthian UI.
Akai APC Key25 MK2 yes yes yes yes yes no Adds SooperLooper looper controls + Levels/Pan/Sync&Quantize/Session save+load; base modes otherwise match the non-SL driver.
Akai MIDI MIX
no yes no no no no Maps mixer functionality (chains 1–16 via banks, master slider, balance, mute/solo, rec-arm).
Akai MPK mini MK3
yes yes no no yes no Modes: Mixer (default), Device UI, Pattern (ZynPad + Pattern Editor), NotePad; plus User and Config modes.
Akai MPK mini MK3 Moder no no no no no yes This is a very simple "Mode Enforcer" driver for the Akai MPK mini MK3.
Novation LAUNCHPAD MINI MK1
yes no no no no no ZynPad driver.
Novation LAUNCHPAD MINI MK3
Novation LAUNCHPAD PRO MK2
Novation LAUNCHPAD PRO MK3
Novation LAUNCHPAD X
Novation LAUNCHKEY MINI MK3
yes yes no no no no Mixer + ZynPad.
Novation LAUNCHKEY 88 MK3
Behringer MOTÖR 61 / 49
yes no no no no no This driver is focused in stage control of setBfree and Pianoteq engines. It also includes the mode enforcer that can be controlled from the pads (notes).
Korg nanoKONTROL
no no no no no no Not currently available.
Korg nanoKONTROL-2
no yes no no no no ZynMixer driver with UI navigation.
Mackie Control
no yes no no no no This driver can be loaded for devices that support MCU protocol and variants.
Fostex Mixtab
no yes no no no no This driver maps the hardware controls to relevant parameters in zynthian (mostly zynmixer).
Teenage Engineering OP-1
no no no no no no Encoder control of parameters and UI navigation via encoders and buttons.
SooperLooper CCx10, for Behringer FCB1010 & others
no no yes yes no no SooperLooper CCx10 controller support.
Worlde Mini Moder Driver
Worlde mini midi keyboard
tbc tbc tbc no no yes
Akai MPK249
Akai mpk249
tbc tbc tbc no no no
Launchkey Mini Mk4 37
Launchkey Mini Mk4
Launchkey Mini Mk3
Launchkey Mini Mk3
yes yes tbc no no no
Launchkey Mk3 88
Launchkey88
Launchkey Mk4 37
Launchkey37-MKIV
Sinco smk25
Arturia Keylab Mk2 61
1 Akai APC Key25 MK2
1.1 The Mixpad mode
1.2 The Device mode
1.3 The Step Sequencer mode
    • K1: note duration
    • K2: note velocity
    • K3: stutter count
    • K4: stutter duration
1 25 / 12 2 / 1 2 / 1
2 50 / 38 4 / 3 4 / 3
3 76 / 63 8 / 6 8 / 6
4 101 / 88 12 / 10 20 / 10
5 127 / 114 20 / 15 40 / 30
1.3.4 Pattern Manager Mode
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
shifting the loops
Shift + and Shift + :
and :
plus the 'global record' on the top left this way acts as a nice shortcut to clear all loops.
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
  • Master Slider: Main volume
    • Lower Knob: Chain's balance
    • Mute: Chain's mute switch
    • Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
  • In bank A:
  • In bank B:
      • PAD 6: toggle audio record.
      • PAD 7: stop audio.
4.3 The Pattern mode
    • Step's velocity: K8.
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Akai MPK mini MK3 Moder
Pad Mode
Pad 1 Chromatic
Pad 2 Major
Pad 3 Minor
Pad 4 Harmonic Minor
Pad 5 Melodic Minor
Pad 6 Dorian
Pad 7 Mixolydian
Pad 8 Lydian
Pad 1 Chromatic
Pad 2 Phrygian
Pad 3 Locrian
Pad 4 Super Locrian
Pad 5 Bhairav
Pad 6 Hungarian Minor
Pad 7 Minor Gypsy
Pad 8 Spanish (8 notes!)
Pad 1 Chromatic
Pad 2 Minor Pentatonic
Pad 3 Major Pentatonic
Pad 4 Hirojoshi
Pad 5 In-Sen
Pad 6 Iwato
Pad 7 Kumoi
Pad 8 NONE
Pad 1 Chromatic
Pad 2 Diminished
Pad 3 Whole-Half
Pad 4 Spanish
Pad 5 Whole Tone
Pad 6 Minor Blues
Pad 7 Pelog
Pad 8 NONE
6 Novation LAUNCHPAD MINI MK1
6.1 ZynPad driver
7 Novation LAUNCHPAD MINI MK3
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK2
8.1 ZynPad driver
9 Novation LAUNCHPAD PRO MK3
9.1 ZynPad driver
10 Novation LAUNCHPAD X
10.1 ZynPad driver
11.1 Mixer & ZynPad driver
12 Novation LAUNCHKEY 88 MK3
12.1 Mixer & ZynPad driver
13 Behringer MOTÖR 61 / 49
This driver is focused in stage control of setBfree and Pianoteq engines. It also includes the mode enforcer that can be controlled from the pads (notes). This driver must be loaded in the device's MIDI port 1. Please, note that you can also load, simultaneously if needed, the generic Mackie driver in the MIDI port 2.
Control Engine Parameter
Fader 1 setBfree Upper DB 16
Fader 3 setBfree Upper DB 8
Fader 4 setBfree Upper DB 4
Fader 6 setBfree Upper DB 2
Fader 1 setBfree Lower DB 16
Fader 3 setBfree Lower DB 8
Fader 4 setBfree Lower DB 4
Fader 6 setBfree Lower DB 2
Fader 1 setBfree Pedal DB 16
Fader 3 setBfree Pedal DB 8
Fader 4 setBfree Pedal DB 4
Fader 6 setBfree Pedal DB 2
Encoder 4 setBfree Reverb
Encoder 5 Pianoteq Volume
Encoder 6 Pianoteq Dynamics
Encoder 7 Pianoteq Reverb Mix
Encoders Bank 9-16 setBfree
Encoders Bank 17-24 setBfree
Pad 1 Mode Enforcer Chromatic
Pad 2 Mode Enforcer Major
Pad 3 Mode Enforcer Minor
Pad 6 Mode Enforcer Dorian
Pad 8 Mode Enforcer Lydian
Pad 2 Mode Enforcer Phrygian
Pad 3 Mode Enforcer Locrian
Pad 5 Mode Enforcer Bhairav
Pad 4 Mode Enforcer Hirojoshi
Pad 5 Mode Enforcer In-Sen
Pad 6 Mode Enforcer Iwato
Pad 7 Mode Enforcer Kumoi
Pad 8 Mode Enforcer NONE
Pad 4 Mode Enforcer Spanish
Pad 7 Mode Enforcer Pelog
14 Korg nanoKONTROL
14.1 ZynMixer driver
Not supported yet!
15 Korg nanoKONTROL-2
15.1 ZynMixer driver
15.1.1 Common buttons
  • Track Left: UI Left arrow
  • Track Right: UI RIGHT arrow
  • Marker Left: UI UP arrow
  • Marker Right: UI DOWN arrow
15.1.2 NORMAL mode
    • Knob: Chain's balance
    • M: Chain's mute switch
    • S: Chain's solo switch
15.1.3 SHIFT mode
  • Strip 8: Main mixer control
    • Slider: Main volume
    • M: Main mute switch
    • R: Main recorder arm switch
16 Mackie Control
  • Original MCU hardware
  • Behringer X-Touch
  • Behringer BCF2000
  • Zoom R8
  • Etc.
17 Fostex Mixtab
  • AUX
  • EQ HI
  • EQ LO
  • PAN
  • MUTE
  • FADER
18 Teenage Engineering OP-1
18.1 Configuring the OP-1
  • Press Shift + COM Button
18.2 Usage
  • Tempo
  • Play/record toggle
  • Arrows up-down, left-right
19 SooperLooper CCx10, for Behringer FCB1010 & others
Pedal CC What it does
1 15 Mute current loop (stop recording if needed) → advance to next loop → arm it for recording
2 16 Solo-trigger loop 2: mute loops 3–5, trigger loop 2
3 17 Solo-trigger loop 3: mute loops 2, 4, 5, trigger loop 3
4 18 Solo-trigger loop 4: mute loops 2, 3, 5, trigger loop 4
5 19 Solo-trigger loop 5: mute loops 2, 3, 4, trigger loop 5
6 20 Advance to the next loop (selection only — nothing is muted or triggered)
7 21 Mute the currently selected loop
8 22 Start/stop recording on the currently selected loop
9 23 Soft reset: stop all recording, mute everything, reselect loop 1, re-sync. Recorded audio is kept.
10 24 Start/stop recording — mapped directly in Zynthian to Record Loop 1 (not managed through the ctrldev driver)
This drivers has been originally designed for the Behringer FCB1010, but it can be used with any MIDI controller sending the right MIDI CC as described in the table below.
Each pedal of the FCB1010 is mapped to CC and SooperLooper as described in the next table. Note that you MUST configure your FCB1010 to send triggers with the specified CC numbers. It won't work with FCB's factory assignments, as they are "frankly daft". Of course, you could configure any other MIDI controller to send the same CC numbers and use it instead, so to some extend, this driver is not exclusive for the FCB1010, although it's been designed with it in mind.
This driver implements a specific, but quite common yet, workflow specially tailored to play Jazz Standards, although it probably suits other genres too. It works like this:
  • Loop 1 is always treated as the timing reference — everything else quantizes to it. I tap in a rhythm, usually with conga drums on my keyboard’s drum pads. I then let that rhythm play out while setting the quantize loop for all remaining loops.
  • I then use Pedal 1 to record verse and chorus sections as separate loops. Each loop is quantized, so I just need to remember to hit “Pedal 1” near the end of the verse to tell SooperLooper to begin recording the next loop. For example, when I’m ready to record the verse, I hit pedal 1 and SooperLooper begins recording Loop 2 on the next beat. When I’m ready to do the chorus, I hit pedal 1 again. SooperLooper finishes recording Loop 2, mutes Loop 2, then begins recording Loop 3 on the next beat, and so on.
  • Sometimes, I will record a verse and then end the recording by hitting Pedal 8, causing that loop to continue playing from the beginning. This allows me to repeat the verse and then only start recording the next loop when I need to play the second ending that goes to the chorus (this is a very common jazz pattern).
  • Once I have recorded my loops, I then click one of the “solo” pedals to begin soloing over the chord changes. In most jazz standards, I go back to the first verse which is on Loop 2, so I click “Pedal 2”. I then click the remaining pedals to go through the rest of the song structure. By triggering each loop, I can have sections of different lengths (again, another thing you’ll commonly find in jazz standards). Everything is quantized to the rhythm track, so moving from loop to loop is all seamless.
The upshot is that this driver allows me to lay down my backing bass and chord track at the beginning of the song, then play this throughout while doing the melody and solos. I think it will work for just about any jazz standard without having to adjust the default 43 second loop length, since four loops (loops 2-5) covers a lot. I can do all of this in real time because each action is done by just one pedal. It’s intuitive because I just hit the pedal assigned to the verse or chorus I want to play and it triggers from the start exactly on the quantized beat.
19.1 Configure the Behringer FCB1010
Here’s how to configure the FCB1010, assuming starting from FCB1010’s factory default:
* Select the pedal you want to program (e.g., 1).
* Long press the Down button (2-3 seconds) to put the pedal in programming mode.
* Short press the Up button.
* By default, “1” is lit, indicating that the pedal is sending a program change. We need it to send a control change (“6”).
* Long press “1” (program change) until it is unlit.
* Long press “6” (control change) until it is lit.
* Short press “6” to program the control change. “6” will start blinking.
* Press Up.
* Enter the CC number you want to set for the pedal. For example, in this ctrldev, I map Pedal 1 to CC 15. Numbers are entered by clicking the pedal numbers in order (e.g., “1” and “5”). The numbers will appear in the LED screen.
* Press Up.
* Enter the value you want to send for the CC. I enter “127” for every control (e.g., “1”, “2”, “7”).
* Press Up. “6” stops blinking and is solidly lit. The pedal is now programmed.
* Long press Down to exit programming mode.
* Repeat 1-13 for each pedal (e.g., Pedal 2 = CC 16, etc.).
I’ve uploaded a demo song (“Night and Day”) that I recorded using my Zynthian setup with this ctrldev driver:
It was recorded live. I hit the record button on the Zynthian to start and stop the recording. Nothing in there was layered on tracks.
Here’s how I progressed through the song structure with the pedals on the FCB1010:
   10: start recording bongos
   10: stop recording bongos
   1: start verse 1
   8: repeat verse 1 (first ending)
   1: stop verse 1, start second ending of verse 1 into chorus
   2: start verse 1
   3: start 2nd ending and chorus
   2-3: continue going back and forth between these for the whole song structure.
   1: record a coda as a new track at the end
   8: repeat coda so I can solo over it.
   9: end song
This will be a real game changer for me to be able to do solo gigs as well as playing with just one other instrument or vocalist. Hopefully this is helpful to others.
20 Technical Info For Driver Developers
# Control device base class
	def __init__(self):
	def setup(self, idev=None):
		if idev != self.idev:
			self.release()
			# Init new selected device
			if idev > 0:
				self.idev = idev
				# Setup routing
				self.init()
				self.refresh(force=True)
	def release(self):
		if self.idev > 0:
				self.end()
			# Restore routing
		self.idev = 0
	# Device MIDI event handler
	def midi_event(self, ev):
	# Light-Off LEDs
	def light_off(self):
	# Sleep On
	def sleep_on(self):
		self.light_off()
	# Sleep On
	def sleep_off(self):
		self.refresh(True)
	def __init__(self):
		super().__init__()
			self.refresh_pads(force)
			self.refresh_zynpad_bank()
		if force:
		pass
		if force:
			self.light_off()
			if changed_state or force:
		pass
