Korg nanoKONTROL Series
1 Korg nanoKONTROL
1.1 ZynMixer driver
Not supported yet!
2 Korg nanoKONTROL 2
2.1 ZynMixer driver
2.1.1 Common buttons
- Track Left: UI Left arrow
- Track Right: UI RIGHT arrow
- Marker Left: UI UP arrow
- Marker Right: UI DOWN arrow
2.1.2 NORMAL mode
- Knob: Chain's balance
- Slider: Chain's volume
- M: Chain's mute switch
- S: Chain's solo switch
2.1.3 SHIFT mode
- Strip 8: Main mixer control
- Slider: Main volume
- M: Main mute switch
- R: Main recorder arm switch
