Zynthian UI User Guide - V5
Revision as of 13:35, 3 November 2023 by Jofemodo (talk | contribs) (→‎Pattern)
  • adjusting parameters
  • the big 5x4 silicone button grid, that adds 20 push buttons with RGB LED feedback, allowing huge improvements in usability.
  • as a consequence, the 4 knobs are often used in quite a different way.
2 Using the push buttons
2.1 Screen access buttons
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Audio Mixer screen
    • Audio Levels screen
  • CTRL/PRESET
    • Control screen
    • Presets/Banks screen
  • ZS3/SNAPSHOT
    • SubSnapShots management
    • Snapshot management
  • METRONOME
    • Tempo screen / Tap-Tempo
  • PAD/STEP
    • ZynPad screen
    • Pattern editor
  • OPT/ADMIN => Long-push to power off!
  • PAD/STEP => Long-push to access arranger screen
2.2 ALT button
2.3 Transport buttons
Pattern editor screen
Audio-player chain
2.4 Navigation buttons
  • Up/Down arrow buttons:
    • Browsing lists and menus.
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
3 Using the knobs
3.1 General rule
  • Knob#1 - #4
    • rotate any knob for controlling the assigned parameters, same as the classic UI. This has not changed.
    • short-push any knob starts MIDI-learning for the associated parameter. Simply move the knob/fader in your MIDI controller and it will be bound.
    • bold-push any knob opens the options menu for the associated parameter.
For navigating the controller screens (select mode), you must push the SEL button. Bold-pushing knob#4 doesn't work anymore for this.
3.3 Mixer
    • short-push / bold-push to open the Audio Mixer's MIDI learning menu.
3.4 Scene (ZynPad)
    • short-push to MIDI learn the current pad by pushing a note in your MIDI controller.
3.5 Pattern
Bold-push in an empty position to edit the default note parameters.
4 Workflow
4.1 Basics
4.2 Sequencer
4.3 Mini-HowTos
5 Work In Progress
