Contributing to Zynthian Development
1 Contributing to Zynthian
1.1 What we expect of you
- fork the repository
- make the changes
- test it
- make a pull request
2 A first time developer
2.6.1 So what is a branch?
2.6.3 Who or what is Oram?
2.6.4 So what is an IDE ?
X -r -s 0
2.7.1 Explorer
2.7.2 Search
2.7.3 Source Control
2.7.4 Run & Debug
2.7.5 Extensions
2.7.6 Remote Explorer
2.7.7 Testing
2.7.8 Accounts
Microsofts domain control
2.7.9 Manage
Admin Tasks
type: X -r -s 0
So we better write some code.
So to repeat,
and press the . key...
on your host machine type:
cd .git
if you now type
ls -las
cat config
We want to change the line
nano config
Not sure.
2.11.2.1 libasound2-dev
2.11.2.2 lv2-dev
2.11.3 Anything else?
There are:
- Juce
- DPF
2.11.4 Juce
2.11.5 DPF
Then make a directory.
2.11.6 So which is better?
3 LV2 Components
3.1 A Notch Filter
Yes, !
3.1.1 DisthroPluginInfo.h
3.1.2 Partial Explanation of DistrhoPluginInfo.h
3.1.3 DisthroPluginMain.cpp
#include "DistrhoPlugin.hpp" START_NAMESPACE_DPF class SimpleGainPlugin : public Plugin { public: SimpleGainPlugin() : Plugin(1, 0, 0) { // 1 parameter, 0 programs, 0 states gain = 1.0f; // Default gain (no change) } protected: const char* getLabel() const override { return "SimpleGain"; } const char* getDescription() const override { return "A simple gain plugin for Zynthian"; } const char* getMaker() const override { return "YourName"; } const char* getLicense() const override { return "MIT"; } uint32_t getVersion() const override { return d_version(1, 0, 0); } int64_t getUniqueId() const override { return d_cconst('S', 'G', 'a', 'n'); } void initParameter(uint32_t index, Parameter& parameter) override { if (index != 0) return; parameter.hints = kParameterIsAutomable; parameter.name = "Gain"; parameter.symbol = "gain"; parameter.unit = "x"; parameter.ranges.def = 1.0f; parameter.ranges.min = 0.0f; parameter.ranges.max = 2.0f; } float getParameterValue(uint32_t index) const override { if (index != 0) return 0.0f; return gain; } void setParameterValue(uint32_t index, float value) override { if (index != 0) return; gain = value; } void run(const float** inputs, float** outputs, uint32_t frames) override { const float* inL = inputs[0]; const float* inR = inputs[1]; float* outL = outputs[0]; float* outR = outputs[1];
for (uint32_t i = 0; i < frames; ++i) { outL[i] = inL[i] * gain; outR[i] = inR[i] * gain; } } private: float gain; DISTRHO_DECLARE_NON_COPYABLE_WITH_LEAK_DETECTOR(SimpleGainPlugin) }; Plugin* createPlugin() { return new SimpleGainPlugin(); } END_NAMESPACE_DPF
3.1.4 Explanation of DistrhoPluginMain.cpp
It includes the header files
we define a class:
So what's the rest of it...
Two sections
- protected:
- private:
3.1.4.1 Protected:
getLabel() const overide { return "SimpleGain"; } getDescription() getMaker() getLicense()
and then do stuff
3.1.4.2 Private:
3.1.4.3 So where do these undefined chunks of code come from?
3.1.5 makefile
3.1.6 makefile what does it do ?
3.2 Auto Leveller
A Place holder for information on the construction of this component and a casual implementation of some kind of document structure.
