Supported plug & play MIDI controllers
(Redirected from Supported MIDI controllers)
Zynthian can be connected to almost any existing MIDI device and you can use the MIDI learning mechanism, as described in the UI user's guide, to assign parameters to faders and knobs in your MIDI controller, for instance. You could also assign pad trigger to notes, etc. But MIDI learning process takes time, it's limiting and you can't get feedback easily. Sometimes it's a lot better to plug a well-known (supported) MIDI controller and get everything mapped automatically. For having this, Zynthian implements a controller driver API that allows developers to create specific drivers for specific devices.
1.1 Supported Drivers and Guides
  • After expanding greatly, the driver page has been split into multiple pages according to similar devices. See Driver Pages for a categorised list of device driver pages.
  • There is also a sortable table of devices to get a glance of what devices have drivers and what functions are available for them. Click the title link to go to the device driver page.
  • As with the rest of the wiki, some information here may be slightly out of date, there may be devices available that aren't shown here. For more up to date info on driver development, see the forum. For a list of drivers currently integrated into Zynthian you can check the (Vangelis version) list on github.
1.2 Accessing Drivers in Zynthian
As the title hints, if you connect your device (via USB), Zynthian will automatically load the driver if a compatible one exists. Where there are multiple drivers for a given device (or to use a generic driver such as Mackie Control, the active driver mode can be selected from within the Midi Input Devices menu from the Chain Manager screen or the individual chain options screen (also the admin menu). Bold press the driver entry for further options.
1.3 Driver Functions
This section contains documentation for some of these controller drivers. There are two core driver functions which control the primary screens in the Zynthian UI:
  • Launcher mode (Zynpad): Launch patterns in the launcher grid interface (as with DAWs like Ableton or Logic)
  • Mixer mode (ZynMixer): Control chain levels, mutes and solo. Different devices may have some additional controls and functions.
There are also additional driver modes/functions depending on the device and driver:
  • UI Navigation: Adds some degree of UI navigation control via arrow buttons or by emulating encoders & buttons on the device
  • SuperLooper Mode: Provides an interface to the native SuperLooper UI within Zynthian for looping live performance.
  • Sequencer Mode (ZynSeq): (Sequencer functionality for the device depends on the Zynthian version installed) Provides some degree of control over the sequencer or pattern editor.
  • Moder Mode: Adjusts device note inputs to stay in scale or provides some chord functionality
2 Driver Pages
3 Table of Device Features
Device Launcher mode (ZynPad) Mixer mode (ZynMixer) UI Navigation SuperLooper mode Sequencer mode (ZynSeq) Moder (chords/scales) Extra features / notes
Akai APC Key25 MK2
yes yes no no yes no Mixpad (default) controls Mixer + ZynPad; also Step Sequencer / pattern editor; Device mode controls the Zynthian UI.
Akai APC Key25 MK2 + SL yes yes yes yes yes no Adds SooperLooper looper controls + Levels/Pan/Sync&Quantize/Session save+load; base modes otherwise match the non-SL driver.
Akai MIDI MIX
no yes no no no no Maps mixer functionality (chains 1–16 via banks, master slider, balance, mute/solo, rec-arm).
Akai MPK mini MK3
yes yes no no yes no Modes: Mixer (default), Device UI, Pattern (ZynPad + Pattern Editor), NotePad; plus User and Config modes.
Akai MPK mini MK3 Moder no no no no no yes This is a very simple "Mode Enforcer" driver for the Akai MPK mini MK3.
Novation LAUNCHPAD MINI MK1
yes no no no no no ZynPad driver.
Novation LAUNCHPAD MINI MK3
Novation LAUNCHPAD PRO MK2
yes yes yes no no no Three modes using the top row buttons:
  • Launcher - similar function to Ableton Live
  • Mixer - volume, pan and (needs testing) sends
  • Device Control - emulates the 20 button array of the V5 and encoder buttons
Novation LAUNCHPAD PRO MK3
Novation LAUNCHPAD X
Novation LAUNCHKEY MINI MK3
yes yes no no no no Mixer + ZynPad.
Novation LAUNCHKEY 88 MK3
Behringer MOTÖR 61 / 49
yes no no no no no This driver is focused in stage control of setBfree and Pianoteq engines. It also includes the mode enforcer that can be controlled from the pads (notes).
Korg nanoKONTROL
no no no no no no Not currently available.
Korg nanoKONTROL-2
no yes no no no no ZynMixer driver with UI navigation.
Mackie Control
no yes no no no no This driver can be loaded for devices that support MCU protocol and variants.
Fostex Mixtab
no yes no no no no This driver maps the hardware controls to relevant parameters in zynthian (mostly zynmixer).
Teenage Engineering OP-1
no no no no no no Encoder control of parameters and UI navigation via encoders and buttons.
SooperLooper CCx10, for Behringer FCB1010 & others
no no yes yes no no SooperLooper CCx10 controller support.
Worlde Mini Moder Driver
Worlde mini midi keyboard
tbc tbc tbc no no yes
Akai MPK249
Akai mpk249
tbc tbc tbc no no no
Launchkey Mini Mk4 37
Launchkey Mini Mk4
Launchkey Mini Mk3
Launchkey Mini Mk3
yes yes tbc no no no
Launchkey Mk3 88
Launchkey88
Launchkey Mk4 37
Launchkey37-MKIV
Sinco smk25
Simco smk25
Arturia Keylab Mk2 61
Arturia keylab mk2 61
yes tbc tbc no no no
4 Technical Info For Driver Developers
Drivers are python modules implementing a class. This class can call internal zynthian-ui API, so it has full access to Zynthian functionality. It’s not limited by CUIA. No limits, so you can break the UI too 😉
dev_ids is a list of identifiers that the driver will match. You can find this by looking at the name of the device in the MIDI Input view in Zynthian. If you bold press the corresponding input to see its options menu, the "Rename port" option shows its USB port / MIDI input name. Use the MIDI input name for your dev_ids list, e.g. Rename port 'USB:2.2/Launchkey Mini MK3 In 2' would provide the device id: "Launchkey Mini MK3 In 2".
# Control device base class
	def __init__(self):
	def setup(self, idev=None):
		if idev != self.idev:
			self.release()
			# Init new selected device
			if idev > 0:
				self.idev = idev
				# Setup routing
				self.init()
				self.refresh(force=True)
	def release(self):
		if self.idev > 0:
				self.end()
			# Restore routing
		self.idev = 0
	# Device MIDI event handler
	def midi_event(self, ev):
	# Light-Off LEDs
	def light_off(self):
	# Sleep On
	def sleep_on(self):
		self.light_off()
	# Sleep On
	def sleep_off(self):
		self.refresh(True)
	def __init__(self):
		super().__init__()
			self.refresh_pads(force)
			self.refresh_zynpad_bank()
		if force:
		pass
		if force:
			self.light_off()
			if changed_state or force:
		pass
5 Driver Discussion on the Forum
Refer to some threads discussing driver development on different devices:
