Contributing to Zynthian Development
1 Contributing to Zynthian
1.1 What we expect of you
- fork the repository
- make the changes
- test it
- make a pull request
2 A first time developer
2.6.1 So what is a branch?
2.6.3 Who or what is Oram?
2.6.4 So what is an IDE ?
X -r -s 0
2.7.1 Explorer
2.7.2 Search
2.7.3 Source Control
2.7.4 Run & Debug
2.7.5 Extensions
2.7.6 Remote Explorer
Access to the Remote Machine
2.7.7 Testing
2.7.8 Accounts
Microsofts domain control
2.7.9 Manage
Admin Tasks
The zynthian has specific setup elements that allow the system to run properly. These are outlined in a file called launch.json which VSC can generate if requested but can be manually created in a directory /zynthian/zynthian-ui/.vscode
type: X -r -s 0
So we better write some code.
It's a Microsoft owned site so vsc helps to iew the code.
So to repeat,
and press the . key...
on your host machine type:
cd .git
if you now type
ls -las
cat config
We want to change the line
nano config
