Contributing to Zynthian Development
Revision as of 08:25, 3 November 2024 by Riban (talk | contribs) (Updated to Oram release and fixed typos.)
1 Contributing to Zynthian
1.1 What we expect of you
  • fork the repository
  • make the changes
  • test it
  • make a pull request
2 A first time developer
Supported_MIDI_controllers
2.6.1 So what is a branch?
2.6.3 Who or what is Oram?
2.6.4 So what is an IDE ?
VSC Download Page
Pi Desktop Download Folder
Pi Desktop VSC menu item
Zynthian home directory
Zynthian-ui directory
systemctl stop zynthian
systemctl start zynthian
systemtl status zynthian
X -r -s 0
  • A VNC server ( A copy of the GUI image that runs in a browser) running on the zynthian to allow the screen to be examined during debugging.
  • Some alterations to the launch.json file in .scode to set things up nicely.
2.7.1 Explorer
2.7.2 Search
2.7.3 Source Control
2.7.4 Run & Debug
2.7.5 Extensions
2.7.6 Remote Explorer
access to the Remote Machine
2.7.7 Testing
2.7.8 Accounts
Microsofts domain control
2.7.9 Manage
Admin Tasks
   "version": "0.2.0",
   "configurations": [
           "name": "Zynthian",
           "type": "debugpy",
           "request": "launch",
           "justMyCode": true,
           "env": {
               "DISPLAY": ":0"
           "name": "Zynthian Debug",
           "type": "debugpy",
           "justMyCode": true,
           "subProcess": true,
           "env": {
               "DISPLAY": ":0",
               "ZYNTHIAN_LOG_LEVEL": "10"
type: X -r -s 0
Zynthian page at Github
So we better write some code.
and press the . key...
on your host machine type:
cd .git
if you now type
ls -las
cat config
[core]
       repositoryformatversion = 0
       filemode = true
       bare = false
       logallrefupdates = true
[remote "origin"]
[branch "master"]
       remote = origin
       merge = refs/heads/master
[branch "testing"]
       remote = origin
       merge = refs/heads/testing
[branch "staging-2209"]
       remote = origin
[branch "stable"]
       remote = origin
       merge = refs/heads/stable
[branch "staging-2307"]
       remote = origin
[branch "chain_manager"]
       remote = origin
We want to change the line
nano config
2.10.1 Where do I put, what files to make it work?
Well there is one other thing that needs doing to ensure the file you have added is included in the scan the zynthian makes to detect device drivers it knows about and that is to add the details of your file into the rather peculiarly named __init__.py file . . THis is a default file that python likes to see in a directory to tell it what is and is not required elsewhere.... As of (09/04/2024) it looks like this...
The __all__ is a python directive to publish these modules and it means they can be seen as fully fledged members of the zynthian namespace.
  1. -*- coding: utf-8 -*-
__all__ = [
   "zynthian_ctrldev_duopiano",
   "zynthian_ctrldev_riband",
This needs to match the naming of your script, Which is the file zyngine/ctrldev/zynthian_ctrldev_behringer_motor61.py, which in my case I copied from the Duo_piano File...
