Contributing to Zynthian Development
1 Contributing to Zynthian
1.1 What we expect of you
  • fork the repository
  • make the changes
  • test it
  • make a pull request
2 A first time developer
Supported_MIDI_controllers
2.6.1 So what is a branch?
2.6.3 So what is an IDE ?
VSC Download Page
Pi Desktop Download Folder
Pi Desktop VSC menu item
Zynthian home directory
Zynthian-ui directory
systemctl stop zynthian
systemctl start zynthian
systemtl status zynthian
X -r -s 0
2.6.9 How so I start the Debugger in VSC?
A careful balancing act is required here because there are a lot of entities attempting to work harmoniously here and a Pi can be a small world. 1/ The zynthian running on Pi, preferably as meaty as one can get. A Pi3 for instance will run out of resources with more recent engines. 2/ A Separate Computer Host from where the operation is all controlled.
2.6.9.1 Explorer
2.6.9.2 Search
2.6.9.3 Source Control
2.6.9.4 Run & Debug
2.6.10 =Extensions
2.6.10.1 Remote Explorer
access to the Remote Machine
2.6.10.2 Tesing
2.6.10.3 Accounts
Microsofts domain control
2.6.10.4 Manage
Admin Tasks
2.6.11 How do I tell the world about my contribution...?
Zynthian page at Github
So we better write some code.
and press the . key...
on your host machine type:
2.8.3 How Do I redirect the zynthian code in zynthian-ui to my personnal repository rather than the zynthian master I forked from ?
cd .git
if you now type
ls -las
cat config
[core]
       repositoryformatversion = 0
       filemode = true
       bare = false
       logallrefupdates = true
[remote "origin"]
[branch "master"]
       remote = origin
       merge = refs/heads/master
[branch "testing"]
       remote = origin
       merge = refs/heads/testing
[branch "staging-2209"]
       remote = origin
[branch "stable"]
       remote = origin
       merge = refs/heads/stable
[branch "staging-2307"]
       remote = origin
[branch "chain_manager"]
       remote = origin
We want to change the line
nano config
2.8.4 How Do I Start a new branch and what should I call it ?
2.8.7 Can I see a diagram of the various branches in the zynthian github page ?
