Zynthian Code development
1 Contributing to Zynthian
1.1 What we expect of you
If you are an occasional contributor, you should follow this procedure:
  • fork the repository
  • make the changes
  • test it
  • make a pull request
2 A first time developer
Supported_MIDI_controllers
2.6.1 So what is a branch?
2.6.3 Who or what is Oram?
