Akai MPK Series
1 Akai MPK mini MK3
1.1 The Mixer mode
1.2 The Device mode
  • In bank A:
  • In bank B:
      • PAD 6: toggle audio record.
      • PAD 7: stop audio.
1.3 The Pattern mode
    • Step's velocity: K8.
In Zynpad, you may:
1.4 The NotePad mode
1.5 The User mode
1.6 The Config mode
2 Akai MPK mini MK3 Moder
Pad Mode
Pad 1 Chromatic
Pad 2 Major
Pad 3 Minor
Pad 4 Harmonic Minor
Pad 5 Melodic Minor
Pad 6 Dorian
Pad 7 Mixolydian
Pad 8 Lydian
Pad 1 Chromatic
Pad 2 Phrygian
Pad 3 Locrian
Pad 4 Super Locrian
Pad 5 Bhairav
Pad 6 Hungarian Minor
Pad 7 Minor Gypsy
Pad 8 Spanish (8 notes!)
Pad 1 Chromatic
Pad 2 Minor Pentatonic
Pad 3 Major Pentatonic
Pad 4 Hirojoshi
Pad 5 In-Sen
Pad 6 Iwato
Pad 7 Kumoi
Pad 8 NONE
Pad 1 Chromatic
Pad 2 Diminished
Pad 3 Whole-Half
Pad 4 Spanish
Pad 5 Whole Tone
Pad 6 Minor Blues
Pad 7 Pelog
Pad 8 NONE
3 Akai MPK249
Akai mpk249
  • Faders and knobs on Control Bank A are mapped to the first 7 chains and master channel volumes and balance. Control Bank B knobs to control the Sends and Return on a Reverb chain (which the user has to create).
  • The toggle buttons on Control Bank A are mutes, solos on B, On B, the 8th button is a fade out.
  • The loop button will initially take you to the ZynPad screen. If you are already on the ZynPad screen, it will take you into the selected loop.
  • Stop, Play and Record should behave as you would expect them to.
  • The rewind button clears the current loop, and the fast-forward button duplicates the loop pattern to the next channel.
  • The drum pads are addressed in an 8x8 grid, to address up to 8 loop slots on 8 chains.
4 Akai MPK49
MPK49
Not yet available, requires adaptation from the MPK249 driver!
