Unofficial hardware
1 Considerably out of date ... 2018
2 Displays
- Adafruit PiTFT Touchscreen 2.8" Configuration notes for PiTFT
- OzzMaker PiScreen 2
- WaveShare Displays with GPIO touch-device
- Official Raspberry Pi Foundation 7" Touch-screen Display
- Generic HDMI Displays with USB mouse-like touch-device
3 Considerably out of date ... 2018
4 Audio interfaces
The Zynthian SD image won’t work without a proper audio device (DAC). The RBPi integrated “audio device” is not suitable (as it has poor performance). The SD image is pre-configured to work with HifiBerry DAC+, although you can use any DAC that works with RBPi (i.e. any I2S device). See Configuring Audio Devices
4.1 Tested good
- HifiBerry
- HifiBerry DAC+ => hifiberry-dacplus
- Hifiberry DAC+ Pro => hifiberry-dacplus
- HifiBerry DAC+ Lite => hifiberry-dac
- HifiBerry Amp => hifiberry-amp
- HifiBerry Digi => hifiberry-digi
- IQAudio
- IQAudio DAC+ => iqaudio-dacplus
- AudioInjector
- AudioInjector Hat => audioinjector-wm8731-audio has Audio Input But be warned that audioinjector soundcards seem quite problematic. IMHO, the 40 pin header is not very reliable
5 Considerably out of date ... 2018
5.1 Tested - with problems
- PiSound https://blokas.io/ PiSound itself works. but currently there are GPIO conflicts with current encoders. has Audio Input also has 5pin MIDI In and MIDI OUT
- USB audio interfaces (latency problems) has Audio Input
5.2 Tested bad
- Built-in Raspberry 1/8" audio jack. The onboard RBPi soundcard is not suitable at all. It's PWM based (no DAC!) and only 10 bits of resolution. Also, it has a huge latency. Forget getting a decent result with it. You have to use a decent soundcard (with a DAC!) for RBPi.
5.3 Untested
6 Considerably out of date ... 2018
- Sparkfun JustBoom HAT
- Built-in Raspberry HDMI audio
- IQAudio
- IQAudio Pi-DACZero
- Durio sound http://www.gravitech.us/dusoulsoqufo.html
- ALLO – PIANO HI-FI DAC https://volumio.org/product/allo-piano-hi-fi-dac/
- Mamboberry https://www.collybia.com/product/mamboberry-ls-dac/
- Chinese I2C
- Board Mikroe-506 Proto Audio Codec WM8731 https://aliexpress.com/item/Module-BOARD-MIKROE-506-PROTO-AUDIO-CODEC-WM8731-development-BOARD/32759758896.html?spm=a2g03.10010108.1000016.1.3c744047A0NIyA&isOrigTitle=true
- Wm8731 module audio module mcu fpga music https://aliexpress.com/item/FREE-SHIPPING-Wm8731-module-audio-module-mcu-fpga-music/1674210328.html?spm=a2g0s.8937460.0.0.meWV7T
- UDA1380 Based on I2S Interface https://aliexpress.com/item/UDA1380-Board-UDA-1380-Module-Stereo-Audio-Codecs-Decoder-Based-on-I2S-Interface/700622589.html?spm=a2g03.10010108.1000016.1.3c744047Zan6Wc&isOrigTitle=true
- Chinese USB
