Zynthian Software
1 Stable ZynthianOS SD-image
Stable ZynthianOS - Vangelis (Trixie arm64) (MD5-sum)
2 Unzipping
3 Preparing the SD-card
or if you are a sudoer:
RBPi2 is not longer supported by zynthianOS. If you want to use a RBPi2, you have to build your own SD-image.
4 First Boot
set_first_boot.sh
cat /root/first_boot.log
5 Configuration instructions
7 Build your own SD-image
Building Zynthian with Docker
