Zynthian Software
1 Stable ZynthianOS SD-image
Full Version:
Lite Version (reduced soundfont library):
2 Unzipping
3 Preparing the SD-card
Latest SD-card image weight around 7 GB compressed and around 16 GB unzipped. It includes all the software you need for your zynthian, properly configured for working out-the-box with the latest official kits. After downloading, you have to write it to a suitable SD-card. You need a good-quality SD-card with a minimum size of 32GB. You can use a bigger one if you like, but big SD-card can be more problematic than smaller ones. We don't recommend to go above 64GB.
If you are a GUI guy, we recommend to use RPi-Imager to write the image into the SD-card. The gnome disk tool also works fine, and probably others too. We don't recommend BalenaEtcher anymore because it's causing much trouble lately.
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo pv zynthianos-last-stable.img.xz.img > /dev/sdc
sudo sync
RBPi2 is not longer supported by zynthianOS. If you want to use a RBPi2, you have to build your own SD-image.
4 First Boot
5 Configuration instructions
zynthian versions
7 Build your own SD-image
Building Zynthian with Docker
