Zynthian Software
Revision as of 16:57, 29 May 2025 by Jofemodo (talk | contribs)
1 Stable ZynthianOS SD-image
Full Version:
Lite Version (reduced soundfont library):
2 Unzipping
3 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
RBPi2 is not longer supported by zynthianOS. If you want to use a RBPi2, you have to build your own SD-image.
4 First Boot
5 Configuration instructions
zynthian versions
7 Build your own SD-image
Building Zynthian with Docker
