Zynthian Software
Revision as of 10:37, 24 September 2024 by Jofemodo (talk | contribs) (→‎First Boot)
1 Stable ZynthianOS SD-image
Full Version:
Stable ZynthianOS (MD5-sum)
Lite Version (reduced soundfont library):
2 Testing ZynthianOS SD-image
Full Version:
The testing version contains new features and a lot of fixes but it could also contain new bugs and unknown issues. It may change without notification. Don't use it for production without deep testing! See below for information on how to choose a version.
3 Unzipping
4 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
RBPi2 is not longer supported by zynthianOS. If you want to use a RBPi2, you have to build your own SD-image.
5 First Boot
6 Configuration instructions
zynthian versions
8 Build your own SD-image
Building Zynthian with Docker
