Zynthian Software
Revision as of 11:09, 12 September 2024 by Riban (talk | contribs) (Adds explaination of why users may want different version.)
Stable ZynthianOS (MD5-sum)
The latest testing image, called Oram, is available here:
The testing version contains new features and a lot of fixes but it could also contain new bugs and unknown issues. It may change without notification. Don't use it for production without deep testing! See below for information on how to choose a version.
2 Unzipping
3 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
4 First Boot
First boot could take some time. Be patient and wait until you see the splash screen with the logo. If you have a recent kit (V3, V4 & V5) and the display remains black after 1 minute, please, re-check the instructions above and re-burn the SD-card again. If this still doesn't work, try with a different SD-card before reporting in the forum. For solving SD-card issues, it could be useful to check the RPi4 status LEDs.
5 Configuration instructions
zynthian versions
7 Build your own SD-image
Building Zynthian with Docker
