Zynthian Software
Revision as of 07:01, 12 September 2024 by Riban (talk | contribs) (Adds release versions)
Stable ZynthianOS (MD5-sum)
The latest testing image, called Oram, is available here:
The testing version contains new features and a lot of fixes but it could also contain new bugs and unknown issues. It may change without notification. Don't use it for production without deep testing! See below for information on how to choose a version.
2 Unzipping
3 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
4 First Boot
First boot could take some time. Be patient and wait until you see the splash screen with the logo. If you have a recent kit (V3, V4 & V5) and the display remains black after 1 minute, please, re-check the instructions above and re-burn the SD-card again. If this still doesn't work, try with a different SD-card before reporting in the forum. For solving SD-card issues, it could be useful to check the RPi4 status LEDs.
5 Configuration instructions
The image you download will set zynthian to the corresponding version, e.g. if you download the stable image then your zynthian will be configured to use that stable release. You can change the version in webconf -> Software options. The table below details how each version behaves and gives some hint as to which you may prefer.
zynthian versions
Staging oram Adventurous Staging branch is where fixes and enhancements to the current stable release are tested before being released in the next point release. Users who want to use the latest version with fairly low risk and early access to updates may choose this version. If you were using staging before its major release, you will continue with the same update experience.
Next Staging strauss Wreckless The bleeding edge development for the next major release. This branch will change without warning and my be broken at any time. For developers and the most adventurous users.
7 Build your own SD-image
Building Zynthian with Docker
