Zynthian Software
Stable ZynthianOS (MD5-sum)
The latest testing image, called Oram, is available here:
The testing version contains new features and a lot of fixes but it could also contain new bugs and unknown issues. It may change without notification. Don't use it for production without deep testing! See below for information on how to choose a version.
2 Unzipping
3 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
4 First Boot
5 Configuration instructions
6 Build your own SD-image
Building Zynthian with Docker
