Zynthian Software
Revision as of 13:30, 5 May 2024 by Jofemodo (talk | contribs)
Stable ZynthianOS (MD5-sum)
The latest testing image, called Oram, is available here:
The testing version contains new features and a lot of fixes but it's not totally finished, so it's not recommended for production work.
2 Unzipping
3 Preparing the SD-card
umount /dev/sdc1
sync
or if you are a sudoer:
sudo umount /dev/sdc1
sudo sync
4 First Boot
5 Configuration instructions
6 Build your own SD-image
Building Zynthian with Docker
