Refactoring Zynthians factory soundfont library
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
- CC-0: OK. You can do whatever you like with these samples. Because we value intellectual property very much, we'll credit creators and sources anyway. And of course we keep the license file.
- CC-BY: OK. We need to credit the author, which we want to do anyway.
- CC-BY-SA: OK. In my understanding, given ZynthianOS is licensed under GPL-3, the BY-SA is one way compatible to this. So when we credit the author, we're fine.
- CC-BY-NC-SA: OK. In my understanding, the ZynthianOS licensed under GPL-3 independently from the commercial kit being sold, is a non-commercial undertake.
- CC-BY-ND: CRITICAL. We might use this library in unchanged form, which prohibits zynthian specific editing.
- CC BY-NC-ND: CRITICAL. Same as above.
1.4.1 Curating vs. collecting
1.5.2 Level matching?
2 Practice
2.1 Roadmap
- Make decisions concerning the key desing decisions above
- Initiating a publically available github repository based in the existing patches OR create a new blank one only containing folders for categories and edit away
- Drafting the distribution process (including in download image, github pull, webconf package?). Immediate distribution vs. distribution on finishing the project.
- Writing guidelines containing infos on license files, READMEs, target size, target engine, general and category specific common controls and editing notes
- Choosing candidates for including, preferably with CC-0 license
- Editing
- Complying with given license is mandatory. Missing license files are being added from original sources, otherwise soundfont must be dropped. This doesn't apply for missing licenses of the sfz script if that script is obviously trivial (list of regions connecting files with note values). Each Instrument contains a license file regarding samples and scripts and at least a zynthian specific README which can be displayed in the patch selection window. CC-BY-ND licences samples are included by git submodule if it is usable in the recommended soundfont player (i.e. Sfizz)
- Sampleset is usable out of the box by preferred engine (i.e. Sfizz) omiting or replacing opcodes these engines cannot use
- Issues are being fixed
- [Target maximum size and how to achieve it]
- [Limit the number of patches per instrument type?]
- [Unifying multiple files (e.g. articulations) into one]
- [Common folder structure]
- Instrument contains a *.yml file. But for simpler sfz the autogeneration might be sufficient.
- [Common controls]
- [Instrument specific controls]
- [Level matching]
Please note that the purpose of this list is:
- to collect ideas and as an inspiration for identifying good samplesets of either category
- to be enhanced, filled and changed by all members
- not to limit the number of samplesets per instrument type, just add rows as needed.
For "P/S" category, "P" is for "primary" selections to be loaded by default; "S" is for "secondary" selections that will be easily loadable by the user.
Licenses:
- PD - public domain but not explicitly licensed at the source, for secondary only.
- Q - questionable or completely undocumented, for secondary only.
- CC license short name
- GNU GPL & variants
- Unlicense - specifically using Github or similar Unlicense option
| Instrument | source | license | editor | P/S | notes |
| Acoustic Pianos | |||||
| 01 Grand Piano 1 | [Salamander Grand V3] | CC BY | jlearman | P | |
| 01 Grand Piano 2 | [Splendid Grand ] | PD | jlearman | S | |
| 02 Upright Piano | - | - | |||
| 03 Felt Piano | - | - | |||
| 04 Honkytonk | - | - | |||
| 05 Harpsichord | - | - | |||
| Electric Pianos | |||||
| 01 EP Rhodes | [jRhodes3c] | CC BY-NC-SA | jlearman | P | "aka Stereo Rhodes." Looped samples. I plan to relax the license to CC BY-SA |
| 01 EP Rhodes | [jRhodes3d] | CC BY-NC | jlearman | P | Unlooped stereo rhodes. I plan some updates. |
| 01 EP Rhodes | current Rhodes sampleset | TBD | jlearman | P | |
| 02 EP Wurlitzer | - | - | |||
| 03 EP Hohner Pianet T | - | - | |||
| 04 EP Clavinet | - | - | |||
| 05 EP CP70 | - | - | |||
| 06 Synth Keys | - | - | |||
| 07 Sampled Keys | - | - | |||
| Chromatic Percussion | |||||
| 01 Celeste | - | - | |||
| 02 Vibraphone | VCSL Vibraphone | CC-0 | ? | ? | Three articulations (bowed, hard and soft mallet), two velocity layers, sounds great |
| 03 Marimba | VCSL Marimba | CC-0 | ? | ? | Two velocity layers |
| 03 Marimba | [Terkelsen Marimba] | Q | S | ||
| 04 Xylophone | VCSL Xylophone | CC-0 | ? | ? | Three articulations (hard, med, soft mallet), two velocity layers |
| 05 Glockenspiel | VCSL Glockenspiel | CC-0 | ? | ? | Three velocity layers |
| 06 Steel Drums | [jSteelDrum] | Unlicense | jlearman | P | |
| 07 Kalimba | VCSL Kalimba, Kenya | CC-0 | ? | ? | Two round robins, there is another Kalimba in the same folder in the repo |
| 08 Music Box | - | - | |||
| 10 Dulcimer | - | - | |||
| 11 Koto | - | - | |||
| 12 Tubular Bell | - | - | |||
| 13 Church/Charillon Bell | - | - | |||
| 14 Timpani | - | - | |||
| Organs & Reed | |||||
| 01 Drawbar Organ | - | - | - | - | Why bother? I think we should delete this since we have SetBFree |
| 02 Pipe/Church Organ | - | - | |||
| 03 Reed Organ | - | - | |||
| 04 Harmonium | - | - | |||
| 05 Accordion | - | - | |||
| 06 Harmonica | - | - | |||
| 07 Melodica | - | - | |||
| 08 Bagpipes | - | - | |||
| 09 Duduk | - | - | |||
| Synth | Really, why bother? We have real synths. | ||||
| 01 Lead | - | - | |||
| 02 Pad | - | - | |||
| 03 FM/Keys | - | - | |||
| 04 Bass | - | - | |||
| 05 String | - | - | |||
| 06 Brass | - | - | |||
| 07 Organ | - | - | |||
| 08 Arp | - | - | |||
| 09 Modular | - | - | |||
| 10 Theremin | - | - | |||
| Guitar | |||||
| 01 Acoustic Guitar | - | - | |||
| 02 Electric Guitar (Clean) | - | - | |||
| 03 Electric Guitar (Distorted) | - | - | |||
| 04 Jazz Guitar | - | - | |||
| Guitarophone | |||||
| 01 Mandolin | - | - | |||
| 02 Ukulele | - | - | |||
| 03 Banjo | - | - | |||
| 04 Oud | - | - | |||
| 05 Lute | - | - | |||
| 06 Sitar | - | - | |||
| 07 Harp | - | - | |||
| 08 Zither | - | - | |||
| 09 Shamisen | - | - | |||
| Bass | |||||
| 01 Upright Bass | - | - | |||
| 02 Acoustic Bass | - | - | |||
| 03 Electric Bass | - | - | |||
| Strings | |||||
| 01 Violin | - | - | |||
| 02 Viola | - | - | |||
| 03 Cello | - | - | |||
| 04 Double Bass | - | - | |||
| 05 Solo Ensemble | - | - | |||
| 06 Chamber Ensemble | - | - | |||
| 07 Orchestral Ensemble | - | - | |||
| 08 Fiddle | - | - | |||
| Brass | |||||
| 02 Flugelhorn | - | - | |||
| 03 French Horn | - | - | |||
| 04 Trombone | - | - | |||
| 05 Tuba | - | - | |||
| 06 Cimbasso | - | - | |||
| 07 Solo Ensemble | - | - | |||
| 08 Chamber Ensemble | - | - | |||
| 09 Orchestral Ensemble | - | - | |||
| Woodwinds | |||||
| 01 Flute | - | - | |||
| 02 Oboe | - | - | |||
| 03 Bassoon | - | - | |||
| 04 English Horn | - | - | |||
| 05 Recorder | Versilian Recorder CE | CC-BY | ? | ? | Has soprano, alto, tenor, bass, greatbass, and contrabass recorder |
| 06 Pan Flute | - | - | |||
| 07 Tin Whistle | - | - | |||
| 08 Solo Ensemble | - | - | |||
| 09 Chamber Ensemble | - | - | |||
| 10 Orchestral Ensemble | - | - | |||
| Reeds | |||||
| 01 Soprano Saxophone | - | - | |||
| 02 Alto Saxophone | - | - | |||
| 03 Tenor Saxophone | - | - | |||
| 04 Baritone Saxophone | - | - | |||
| 05 Clarinet | - | - | |||
| 06 Bass Clarinet | - | - | |||
| Choirs | |||||
| 01 Solo Voice | - | - | |||
| 02 Choir | - | - | |||
| Acoustic Drums | |||||
| 01 Rock | - | - | |||
| 02 Jazz | - | - | |||
| 03 Brush | - | - | |||
| 04 Mallet | - | - | |||
| Electronic Drums | |||||
| 01 808 | - | - | |||
| 02 909 | - | - | |||
| 03 606 | - | - | |||
| 04 LinnDrum | - | - | |||
| 05 … | - | - | |||
| Percussion | |||||
| 01 Hand Percussion | - | - | |||
| 02 Orchestral Percussion | - | - | |||
| Miscellanious | |||||
| 01 Found Sounds | - | - | |||
| 02 Field Recordings | - | - | |||
| 03 FX | - | - | |||
