Refactoring Zynthians factory soundfont library
Revision as of 21:01, 26 February 2026 by Hannesmenzel (talk | contribs)
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
1.4.1 Curating vs. collecting
1.5.2 Level matching?
2 Practice
2.1 Roadmap
  6. Editing
  • Issues are being fixed
  • [Common folder structure]
  • [Common controls]
  • [Level matching]
Soundfont candidates
Type soundfont proposals / description editor
A Acoustic Pianos - -
01 Grand Piano Salamander V3? -
02 Upright Piano - -
03 Felt Piano - -
04 Honkytonk - -
05 Harpsichord - -
B Electric Pianos - -
01 EP Rhodes - -
02 EP Wurlitzer - -
03 EP Hohner Pianet T - -
04 EP Clavinet - -
05 EP CP70 - -
06 Synth Keys - -
07 Sampled Keys - -
C Chromatic Percussion - -
01 Celeste - -
02 Vibraphone - -
03 Marimba - -
04 Xylophone - -
05 Glockenspiel - -
06 Steel Drums - -
07 Kalimba - -
08 Music Box - -
10 Dulcimer - -
11 Koto - -
12 Tubular Bell - -
13 Church/Charillon Bell - -
14 Timpani - -
D Organs & Reed - -
01 Drawbar Organ - -
02 Pipe/Church Organ - -
03 Reed Organ - -
04 Harmonium - -
05 Accordion - -
06 Harmonica - -
07 Melodica - -
08 Bagpipes - -
09 Duduk - -
E Synth - -
01 Lead - -
02 Pad - -
03 FM/Keys - -
04 Bass - -
05 String - -
06 Brass - -
07 Organ - -
08 Arp - -
09 Modular - -
10 Theremin - -
F Guitar - -
01 Acoustic Guitar - -
02 Electric Guitar (Clean) - -
03 Electric Guitar (Distorted) - -
04 Jazz Guitar - -
G Guitarophone - -
01 Mandolin - -
02 Ukulele - -
03 Banjo - -
04 Oud - -
05 Lute - -
06 Sitar - -
07 Harp - -
08 Zither - -
09 Shamisen - -
H Bass - -
01 Upright Bass - -
02 Acoustic Bass - -
03 Electric Bass - -
I Strings - -
01 Violin - -
02 Viola - -
03 Cello - -
04 Double Bass - -
05 Solo Ensemble - -
06 Chamber Ensemble - -
07 Orchestral Ensemble - -
08 Fiddle - -
J Brass - -
01 Trumpet VSCO2 CE Trumpet has many articulations with around 100 MB in size and CC-0 hannesmenzel
02 Flugelhorn - -
03 French Horn - -
04 Trombone - -
05 Tuba - -
06 Cimbasso - -
07 Solo Ensemble - -
08 Chamber Ensemble - -
09 Orchestral Ensemble - -
K Woodwinds - -
01 Flute - -
02 Oboe - -
03 Bassoon - -
04 English Horn - -
05 Recorder - -
06 Pan Flute - -
07 Tin Whistle - -
08 Solo Ensemble - -
09 Chamber Ensemble - -
10 Orchestral Ensemble - -
L Reeds - -
01 Soprano Saxophone - -
02 Alto Saxophone - -
03 Tenor Saxophone - -
04 Baritone Saxophone - -
05 Clarinet - -
06 Bass Clarinet - -
M Choirs - -
01 Solo Voice - -
02 Choir - -
N Acoustic Drums - -
01 Rock - -
02 Jazz - -
03 Brush - -
04 Mallet - -
O Electronic Drums - -
01 808 - -
02 909 - -
03 606 - -
04 LinnDrum - -
05 … - -
P Percussion - -
01 Hand Percussion - -
02 Orchestral Percussion - -
Q Miscellanious - -
01 Found Sounds - -
02 Field Recordings - -
03 FX - -
2.4 Changelog/Current edits
