Refactoring Zynthians factory soundfont library
Revision as of 12:45, 26 February 2026 by Hannesmenzel (talk | contribs)
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
1.4.1 Curating vs. collecting
1.5.2 Level matching?
2 Practice
2.1 Roadmap
  6. Editing
  • Issues are being fixed
  • [Common folder structure]
  • [Common controls]
  • [Level matching]
2.4 Changelog/Current edits
