Refactoring Zynthians factory soundfont library
Revision as of 11:46, 26 February 2026 by Hannesmenzel (talk | contribs)
The ongoing discussion is about using upstream libraries maintained in other sources vs. hosting an own copy of a set of soundfonts, e.g. on Github. Up to now the soundfonts are distributed together with the ZynthianOS image. The question is where to store the storage intense sample files.
1.4.1 Curating vs. collecting
1.5.2 Level matching?
2 Practice
2.1 Roadmap
  6. Editing
  • Issues are being fixed
  • [Common folder structure]
  • [Common controls]
  • [Level matching]
2.4 Changelog/Current edits
