Refactoring Zynthians factory soundfont library
1 Theory
The ongoing discussion is about using upstream libraries maintained in other sources vs. hosting an own copy of a set of soundfonts, e.g. on Github. Up to now the soundfonts are distributed together with the ZynthianOS image. The question is where to store the storage intense sample files.
1.6 Design Decisions: We have to do make some decisions here
1.6.1 Pulling upstream soundfont libraries vs. hosting own repository vs. hybrid approach
1.6.2 Targeting one specific engine vs. targeting all engines
1.6.3 Curating vs. collecting
1.6.4 Level matching?
2 Practice
2.1 Roadmap
- Make decisions concerning the key desing decisions above
- Initiating a publically available github repository based in the existing patches OR create a new blank one only containing folders for categories and edit away
- Drafting the distribution process (including in download image, github pull, webconf package?). Immediate distribution vs. distribution on finishing the project.
- Writing guidelines containing infos on license files, READMEs, target size, target engine, general and category specific common controls and editing notes
- Choosing candidates for including, preferably with CC-0 license
- Editing
- Complying with given license is mandatory. Missing license files are being added from original sources, otherwise soundfont must be dropped. This doesn't apply for missing licenses of the sfz script if that script is obviously trivial (list of regions connecting files with note values). Each Instrument contains a license file regarding samples and scripts and at least a zynthian specific README which can be displayed in the patch selection window. CC-BY-ND licences samples are included by git submodule if it is usable in the recommended soundfont player (i.e. Sfizz)
- Sampleset is usable out of the box by preferred engine (i.e. Sfizz) omiting or replacing opcodes these engines cannot use
- Issues are being fixed
- [Target maximum size and how to achieve it]
- [Limit the number of patches per instrument type?]
- [Unifying multiple files (e.g. articulations) into one]
- [Common folder structure]
- Instrument contains a *.yml file. But for simpler sfz the autogeneration might be sufficient.
- [Common controls]
- [Instrument specific controls]
- [Level matching]
