Integrated Development Environments (IDE)
1 So what is an IDE ?
It's Microsoft's Visual Studio code, https://code.visualstudio.com/ known to friends and enemies alike as VSC (or VSCode).
It will install and you will have a new icon appear in your desktop menu in the Programming section.
1.4 What happens if zynthian crashes and how do I stop it restarting on errors ?
X -r -s 0
2 How do I Debug a Zynthian?
2.1 Explorer
2.2 Search
2.3 Source Control
2.4 Run & Debug
2.5 Extensions
2.6 Remote Explorer
2.7 Testing
2.8 Accounts
Microsofts domain control
2.9 Manage
Admin Tasks
Here is an example launch.json for debugging zynthian:
{// Use IntelliSense to learn about possible attributes.
"version": "0.2.0",
"configurations": [
"name": "Zynthian",
"type": "debugpy",
"request": "launch",
"justMyCode": true,
"env": {
"DISPLAY": ":0"
"name": "Zynthian Debug",
"type": "debugpy",
"justMyCode": true,
"subProcess": true,
"env": {
"DISPLAY": ":0",
"ZYNTHIAN_LOG_LEVEL": "10"
This will stop the zynthian process, and your GUI Screen will disappear and the zynth won't make any sound. (well it shouldn't). Other processes like webconf will continue to work so we only need to restart the zynthian from within VSC to allow us access to VSC debugging facilities.
type: X -r -s 0
Congratulations if you get this far. You have just won an open source gold star by having a PR accepted by an open source project!
So we better write some code.
3 It is 'suggested' one creates a task/issue? how do I do that ?
So to repeat,
3.1 So what have we gained here ?
and press the . key...
on your host machine type:
4.3 How Do I redirect the zynthian code in zynthian-ui to my personnal repository rather than the zynthian master I forked from ?
cd .git
if you now type
ls -las
we want to modify the config file in this folder... So lets look at this file first to see what's in it . . .
cat config
[core]
repositoryformatversion = 0
filemode = true
bare = false
logallrefupdates = true
[remote "origin"]
[branch "master"]
remote = origin
merge = refs/heads/master
[branch "testing"]
remote = origin
merge = refs/heads/testing
[branch "staging-2209"]
remote = origin
[branch "stable"]
remote = origin
merge = refs/heads/stable
[branch "staging-2307"]
remote = origin
[branch "chain_manager"]
remote = origin
We want to change the line
nano config
4.4 How Do I Start a new branch and what should I call it ?
The VSC status bar at the very bottom of the screen contains a lot of useful information. It shows the remote machine you are logged onto and it shows the current branch you are located on.
4.7 Can I see a diagram of the various branches in the zynthian github page ?
