LV2
1 LV2 Components
1.1 A Notch Filter
1.1.1 The Definition Files
1.1.2 The Code components
1.1.2.1 DisthroPluginInfo.h
1.1.2.2 Partial Explanation of DistrhoPluginInfo.h
1.1.2.3 DisthroPluginMain.cpp
#include "DistrhoPlugin.hpp" START_NAMESPACE_DPF class SimpleGainPlugin : public Plugin { public: SimpleGainPlugin() : Plugin(1, 0, 0) { // 1 parameter, 0 programs, 0 states gain = 1.0f; // Default gain (no change) } protected: const char* getLabel() const override { return "SimpleGain"; } const char* getDescription() const override { return "A simple gain plugin for Zynthian"; } const char* getMaker() const override { return "YourName"; } const char* getLicense() const override { return "MIT"; } uint32_t getVersion() const override { return d_version(1, 0, 0); } int64_t getUniqueId() const override { return d_cconst('S', 'G', 'a', 'n'); } void initParameter(uint32_t index, Parameter& parameter) override { if (index != 0) return; parameter.hints = kParameterIsAutomable; parameter.name = "Gain"; parameter.symbol = "gain"; parameter.unit = "x"; parameter.ranges.def = 1.0f; parameter.ranges.min = 0.0f; parameter.ranges.max = 2.0f; } float getParameterValue(uint32_t index) const override { if (index != 0) return 0.0f; return gain; } void setParameterValue(uint32_t index, float value) override { if (index != 0) return; gain = value; } void run(const float** inputs, float** outputs, uint32_t frames) override { const float* inL = inputs[0]; const float* inR = inputs[1]; float* outL = outputs[0]; float* outR = outputs[1];
for (uint32_t i = 0; i < frames; ++i) { outL[i] = inL[i] * gain; outR[i] = inR[i] * gain; } } private: float gain; DISTRHO_DECLARE_NON_COPYABLE_WITH_LEAK_DETECTOR(SimpleGainPlugin) }; Plugin* createPlugin() { return new SimpleGainPlugin(); } END_NAMESPACE_DPF
1.1.2.4 Explanation of DistrhoPluginMain.cpp
It includes the header files
we define a class:
So what's the rest of it...
Two sections
- protected:
- private:
1.1.2.4.1 Protected:
getLabel() const overide { return "SimpleGain"; } getDescription() getMaker() getLicense()
and then do stuff
1.1.2.4.2 Private:
1.1.2.4.3 So where do these undefined chunks of code come from?
1.1.2.5 makefile
1.1.2.6 makefile what does it do ?
1.2 Auto Leveller
A Place holder for information on the construction of this component and a casual implementation of some kind of document structure.
1.2.1 What is it?
You can think of it as your angry sound engineer in a live situation, both during soundcheck and during the gig. Initially it will turn your output volume down to a reasonable level. It will also do that if anything unforseen happens in the chain (you add another plugin which features an integer gain multiplier and is set to gain=20). When set the right values (try the preset “Tuned”) it should level any source to a loudness level somewhere into yellow meter territory.
It also features two programs:
1.2.2 Parameters
1.2.2.1 Pre Gain (dBfs)
Adjust the pre amplification in case you deal with quieter sources (like soundfonts) you want to boost before getting into the automatic levelling.
1.2.2.2 Theshold Peak (dBfs)
Set your maximum peak levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. Recommended values are between 0 and -4 dBfs.
1.2.2.3 Theshold RMS (dBfs)
Set your maximum RMS levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. The detector is estimating RMS values of a 300ms window by a using a lowpass filter. Recommended values are between -14 and -18 dBfs.
1.2.2.4 Listen (bool)
When engaged (by default) it will perform detection and level matching. When disengaged it will keep the current gain, but will not further listen. If engaged again, the gain reduction will be reset.
2 LV2 custom control groups (ttl)
If not edited further, LV2 parameters will be presented in a manner being sorted by their parameter ID and grouped in groups of four without helpful group names. We can edit a specific file to get some more helpful named and ordered parameter groups. It is highly recommended to study other custom control ttl files before edit your own one.
2.1 Location
On any zynthian update database regeneration zynthian will replace the original ttl file with the ones in /zynthian/zynthian-data/lv2-custom.
2.2 Editing the ttl file
2.2.1 Namespace prefixes
Most of the time we have to add some lines to the header, if not already present:
@prefix rdf: <http://www.w3.org/1999/02/22-rdf-syntax-ns#> . @prefix pg: <http://lv2plug.in/ns/ext/port-groups#> . @prefix plug: <COPY URN FROM PLUGIN BLOCK> .
2.2.2 Control groups
Add control groups like that outside the plugin block, for example right at the end of the file. Groups with higher displayPriority values will be displayed on top of your parameter group view. GROUP1 and the symbol "group1" can be named yourself (only letters, numbers or _", name "Group1 Display Name" you can also edited and will show on your UI.
plug:GROUP1 a pg:ControlGroup ; lv2:name "Group1 Display Name" ; lv2:symbol "group1" ; lv2:displayPriority 3 . plug:GROUP2 a pg:ControlGroup ; lv2:name "Group2 Display Name" ; lv2:symbol "group2" ; lv2:displayPriority 2 . ...
2.2.3 Parameter assignment
Add following lines to every control port representing a parameter (contains "a lv2:ControlPort", so not the audio input and output ports), while display priority goes from higher to lower numbers as well:
pg:group plug:GROUP1 ; lv2:displayPriority 1 ;
2.2.4 Scale Points
This is especially helpful for integer or boolean like enumeration parameters and other parameters which should have stepped controls. Here we have an example for a boolean parameter, which should only be in state "On" or "Off":
lv2:scalePoint [ rdf:value 0.0 ; rdfs:label "OFF" ; rdfs:comment "OFF" ; ], [ rdf:value 1.0 ; rdfs:label "ON" ; rdfs:comment "ON" ; ];
It has to be like that because typically (oftentimes, but not necessarily) parameters are represented as floating point values (0.000f to 1.000f), even if they're supposed to be boolean or integer, even if LV2 would support these kind of data. Other parameters could be of "integer logic". Let's assume the parameter "Waveform" would have the states "Saw, Sine, Square, Triange", we may assume that every floating point value from 0.0f to <0.25f represents "Saw" and so on. Then we might try this (while value and label are mandatory, comment is not):
lv2:scalePoint [ rdf:value 0.0 ; rdfs:label "Saw" ; rdfs:comment "Saw" ; ], [ rdf:value 0.25 ; rdfs:label "Sine" ; rdfs:comment "Sine" ; ], [ rdf:value 0.5 ; rdfs:label "Square" ; rdfs:comment "Square" ; ], [ rdf:value 0.75 ; rdfs:label "Triangle" ; rdfs:comment "Triangle" ; ];
2.2.5 Disable parameter from being shown on UI
Sometimes we have parameters which have no function and must not be displayed. You add the following line to the parameter definition:
lv2:portProperty pp:notOnGUI ;
2.2.6 Summary parameter definition
So a single parameter should for example look like this:
[ a lv2:InputPort, lv2:ControlPort ; lv2:index 8 ; lv2:symbol "delaytimesync" ; lv2:name "Host Sync" ; lv2:default 0.473684 ; lv2:minimum 0.0 ; lv2:maximum 1.0 ; pg:group plug:DELAY ; lv2:displayPriority 2 ; lv2:scalePoint [ rdf:value 0.0 ; rdfs:label "Free" ; rdfs:comment "Free" ; ], [ rdf:value 0.052631 ; rdfs:label "1/16" ; rdfs:comment "1/16" ; ], [ rdf:value 0.105263 ; rdfs:label "1/8" ; rdfs:comment "1/8" ; ], [ rdf:value 0.157895 ; rdfs:label "1/4" ; rdfs:comment "1/4" ; ], [ rdf:value 0.211053 ; rdfs:label "1/2" ; rdfs:comment "1/2" ; ], [ rdf:value 0.263158 ; rdfs:label "1/1" ; rdfs:comment "1/1" ; ], [ rdf:value 0.315789 ; rdfs:label "2/1" ; rdfs:comment "2/1" ; ], [ rdf:value 0.368421 ; rdfs:label "1/16." ; rdfs:comment "1/16." ; ], [ rdf:value 0.421052 ; rdfs:label "1/8." ; rdfs:comment "1/8." ; ], [ rdf:value 0.473684 ; rdfs:label "1/4." ; rdfs:comment "1/4." ; ], [ rdf:value 0.526316 ; rdfs:label "1/2." ; rdfs:comment "1/2." ; ], [ rdf:value 0.578947 ; rdfs:label "1/1." ; rdfs:comment "1/1." ; ], [ rdf:value 0.631579 ; rdfs:label "2/1." ; rdfs:comment "2/1." ; ], [ rdf:value 0.684211 ; rdfs:label "1/16T" ; rdfs:comment "1/16T" ; ], [ rdf:value 0.736842 ; rdfs:label "1/8T" ; rdfs:comment "1/8T" ; ], [ rdf:value 0.789474 ; rdfs:label "1/4T" ; rdfs:comment "1/4T" ; ], [ rdf:value 0.842105 ; rdfs:label "1/2T" ; rdfs:comment "1/2T" ; ], [ rdf:value 0.894736 ; rdfs:label "1/1T" ; rdfs:comment "1/1T" ; ], [ rdf:value 0.947368 ; rdfs:label "2/1T" ; rdfs:comment "2/1T" ; ], [ rdf:value 1.0 ; rdfs:label "-" ; rdfs:comment "-" ; ]; ] ,
The bold line is the one we started to insert things. You typically should only edit the "name" value, which is the display label and the newly added values. In this case we added the control to the previously added group named "DELAY", added the displayPriority, so that it will be displayed within the group above all parameters with value <2 and below paramters with value >2. Then we added stepped controls for delay times defined by subdivisions of the host tempo, where the values represent 1/19, 2/19, 3/19... Continuous parameters typically do not need scale points at all, rather they would become stepped parameters as well if we'd add them.
2.3 Recommended workflow
Instead of just copying the ttl over to the respective directory and edit it for your own use you can make things easier for the devs to implement your custom feature and share it with everybody this way:
- Fork the zynthian/zynthian-data repositories vangelis branch
- Checkout to that branch in your zynthian
- Develop using your fork
- Make a pull request
