LV2
1 LV2 Components
1.1 A Notch Filter
1.1.1 The Definition Files
1.1.2 The Code components
1.1.2.1 DisthroPluginInfo.h
1.1.2.2 Partial Explanation of DistrhoPluginInfo.h
1.1.2.3 DisthroPluginMain.cpp
#include "DistrhoPlugin.hpp" START_NAMESPACE_DPF class SimpleGainPlugin : public Plugin { public: SimpleGainPlugin() : Plugin(1, 0, 0) { // 1 parameter, 0 programs, 0 states gain = 1.0f; // Default gain (no change) } protected: const char* getLabel() const override { return "SimpleGain"; } const char* getDescription() const override { return "A simple gain plugin for Zynthian"; } const char* getMaker() const override { return "YourName"; } const char* getLicense() const override { return "MIT"; } uint32_t getVersion() const override { return d_version(1, 0, 0); } int64_t getUniqueId() const override { return d_cconst('S', 'G', 'a', 'n'); } void initParameter(uint32_t index, Parameter& parameter) override { if (index != 0) return; parameter.hints = kParameterIsAutomable; parameter.name = "Gain"; parameter.symbol = "gain"; parameter.unit = "x"; parameter.ranges.def = 1.0f; parameter.ranges.min = 0.0f; parameter.ranges.max = 2.0f; } float getParameterValue(uint32_t index) const override { if (index != 0) return 0.0f; return gain; } void setParameterValue(uint32_t index, float value) override { if (index != 0) return; gain = value; } void run(const float** inputs, float** outputs, uint32_t frames) override { const float* inL = inputs[0]; const float* inR = inputs[1]; float* outL = outputs[0]; float* outR = outputs[1];
for (uint32_t i = 0; i < frames; ++i) { outL[i] = inL[i] * gain; outR[i] = inR[i] * gain; } } private: float gain; DISTRHO_DECLARE_NON_COPYABLE_WITH_LEAK_DETECTOR(SimpleGainPlugin) }; Plugin* createPlugin() { return new SimpleGainPlugin(); } END_NAMESPACE_DPF
1.1.2.4 Explanation of DistrhoPluginMain.cpp
It includes the header files
we define a class:
So what's the rest of it...
Two sections
- protected:
- private:
1.1.2.4.1 Protected:
getLabel() const overide { return "SimpleGain"; } getDescription() getMaker() getLicense()
and then do stuff
1.1.2.4.2 Private:
1.1.2.4.3 So where do these undefined chunks of code come from?
1.1.2.5 makefile
1.1.2.6 makefile what does it do ?
1.2 Auto Leveller
A Place holder for information on the construction of this component and a casual implementation of some kind of document structure.
1.2.1 What is it?
You can think of it as your angry sound engineer in a live situation, both during soundcheck and during the gig. Initially it will turn your output volume down to a reasonable level. It will also do that if anything unforseen happens in the chain (you add another plugin which features an integer gain multiplier and is set to gain=20). When set the right values (try the preset “Tuned”) it should level any source to a loudness level somewhere into yellow meter territory.
It also features two programs:
1.2.2 Parameters
1.2.2.1 Pre Gain (dBfs)
Adjust the pre amplification in case you deal with quieter sources (like soundfonts) you want to boost before getting into the automatic levelling.
1.2.2.2 Theshold Peak (dBfs)
Set your maximum peak levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. Recommended values are between 0 and -4 dBfs.
1.2.2.3 Theshold RMS (dBfs)
Set your maximum RMS levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. The detector is estimating RMS values of a 300ms window by a using a lowpass filter. Recommended values are between -14 and -18 dBfs.
1.2.2.4 Listen (bool)
When engaged (by default) it will perform detection and level matching. When disengaged it will keep the current gain, but will not further listen. If engaged again, the gain reduction will be reset.
