Assembling Zynthian Kit V5.1
1.1 BOM V5.1 kit
- V5.1 Aluminum Case
- Main Board
- Control Board
- Display
- Raspberry Pi5
- Thermal Block
- Silicone Keypad
- Rubber Feet (4 units)
- Wiring
- Screws
If your main or control board has a round blue sticker, please, pay attention to the specific instructions you will find along this tutorial. They will be displayed in blue warning boxes like this.
- Allen Spanner 1.5 mm
- Allen Spanner 2.0 mm
Don't be worried if your display cable is narrower than the one in the pictures. In recent kit versions, the display cable is 1.1cm wide instead of 1.6cm. The terminations are exactly the same and hereby the connection process is identical.
- 20 x 28 mm
- 14 x 9 mm
- 11 x 11 mm
If your main board is labeled as v.0.9. we have added a round blue sticker on it. In this version, the USB-C FPC connector has bottom contacts and you must insert the ribbon cable with the metal contacts side FACING DOWN. Be aware that the cable goes underneath the tongue, instead of over the tongue like shown in the pictures.
Please, note that the white JST connector shown in the pictures on the left may not be soldered in your control board. Don't worry about it as it's not needed for normal operation.
If your control board is labeled as v.0.6. we have added a round blue sticker on it. In this version, the FPC connector has bottom contacts and you must insert the ribbon cable with the metal contacts side FACING DOWN. Be aware that the cable goes underneath the tongue, instead of over the tongue like shown in the pictures.
If your main board is labeled as v.0.9. we have added a round blue sticker on it. In this version, the control-1 FPC connector has bottom contacts and you must insert the ribbon cable with the metal contacts side FACING DOWN. Be aware that the cable goes underneath the tongue, instead of over the tongue like shown in the pictures.
6 First Boot
set_first_boot.sh
cat /root/first_boot.log
The symptoms
and:
The defect
The fix
- Main Board
- CONTROL-1
- USB-C1
- SDCARD-RBPi1
- Control Board
- CONTROL-1
