Assembling Zynthian Kit V5.1
1.1 BOM V5.1 kit
  • V5.1 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi5
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
Don't be worried if your display cable is narrower than the one in the pictures. In recent kit versions, the display cable is 1.1cm wide instead of 1.6cm. The terminations are exactly the same and hereby the connection process is identical.
  • 20 x 28 mm
  • 14 x 9 mm
  • 11 x 11 mm
Please, note that the white JST connector shown in the pictures on the left may not be soldered in your control board. Don't worry about it as it's not needed for normal operation.
First boot splash screen
6 First Boot
set_first_boot.sh
cat /root/first_boot.log
70: -- -- -- -- -- -- -- --
The symptoms
and:
The defect
The fix
  • Main Board
    • CONTROL-1
    • USB-C1
    • SDCARD-RBPi1
  • Control Board
    • CONTROL-1
