Assembling Zynthian Kit V5.1
Revision as of 18:49, 28 June 2025 by Jawn (talk | contribs) (→‎General Advice: Fix typo ⚡)
1.1 BOM V5.1 kit
  • V5.1 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi5
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
  • 20 x 28 mm
  • 14 x 9 mm
  • 11 x 11 mm
THIS IS A CRITICAL STEP to get the main board SD-card slot working right. Extreme your care because the SD-card adapter's cable is delicate and easy to damage, specially the join between the flat cable and the SD-card plug.
Please, note that the white JST connector shown on the pictures at left may not be soldered in you control board. Don't worry about it as it's not need it for normal operation.
First boot splash screen
6 First Boot
set_first_boot.sh
cat /root/first_boot.log
70: -- -- -- -- -- -- -- --
The symptoms
and:
The defect
The fix
  • Main Board
    • CONTROL-1
    • USB-C1
    • SDCARD-RBPi1
  • Control Board
    • CONTROL-1
