Assembling Zynthian Kit V5.1
1.1 BOM V5.1 kit
- V5.1 Aluminum Case
- Main Board
- Control Board
- Display
- Raspberry Pi5
- Thermal Block
- Silicone Keypad
- Rubber Feet (4 units)
- Wiring
- RBPi5 DSI display flat cable: 20cm long, 1.6cm wide, 1mm/0.5mm pitch, black
- Screws
- Allen Spanner 1.5 mm
- Allen Spanner 2.0 mm
1. Look for the display ribbon cable in the "Screen and Bits" case. It's not inside any plastic bag but it's laying in the cardboard box. It's 20cm long and 1.6cm wide, having different terminations on each side. Most probably it will be labeled as "Display cable 200mm", white text over black cable.
- 20 x 28 mm
- 14 x 9 mm
- 11 x 11 mm
THIS IS A CRITICAL STEP to get the main board SD-card slot working right. Extreme your care because the SD-card adapter's cable is delicate and easy to damage, specially the join between the flat cable and the SD-card plug.
Please, note that the white JST connector shown on the pictures at left may not be soldered in you control board. Don't worry about it as it's not need it for normal operation.
set_first_boot.sh
cat /root/first_boot.log
