Assembling Zynthian Kit V5.1
1.1 BOM V5.1 kit
- V5.1 Aluminum Case
- Main Board
- Control Board
- Display
- Raspberry Pi5
- Thermal Block
- Silicone Keypad
- Rubber Feet (4 units)
- Wiring
- Screws
- Allen Spanner 1.5 mm
- Allen Spanner 2.0 mm
- 20 x 28 mm
- 14 x 9 mm
- 11 x 11 mm
1. Look for the control flat ribbon cable in the wiring bag. It's 15cm long and 1cm wide. Contacts are crossed, with one side faced up and the other side faced down. Be warned that your cable color could be different than those shown in the pictures. It could be grey with blue tips or black with black tips.
Please, note that the white JST connector shown on the pictures at left may not be soldered in you control board. Don't worry about it as it's not need it for normal operation.
3. Insert the ribbon cable into the FPC connector. It must be inserted straight, with the metal contacts side facing up. This cable is reversible, so you can take any of the 2 caps, while taking care of placing the contacts side facing up.
2. Using two fingers, one on each hand, softly pull the main board's control-1 connector tongue until it's open. Insert the flat ribbon cable coming from the control board (top part). Do it straight, without bending or twisting it in any way, so the contacts side is faced up.
