Assembling Zynthian Kit V5.1
Revision as of 02:30, 19 October 2024 by Gmeader (talk | contribs) (→‎BOTTOM PART: clearer instructions on plugging in display cable)
1.1 BOM V5.1 kit
  • V5.1 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi5
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
3. Open the RPi5's DSI connector by softly pulling up on both sides of the tiny black/grey tongue at once. It opens only about 2mm. When it's totally open, push the ribbon cable inside, straight down, with the black shiny side at the end of the cable facing out (towards the HDMI printed on the RPi5 board). The metal teeth on the end of the cable that are pushed into the connector should be facing the RPi5 Ethernet jack. All flat cables in the V5 kit are reversible, so you can either end, while taking care to have the black shiny side facing away from the Ethernet jack. When the cable is tightly inserted, close the connector by pushing down on the tongue with 2 fingers, one of each hand. Pay attention to ensure the cable does not move out of the connector. If it's not well inserted or not straight, repeat the operation until it's OK. Note: There is no blue side shown in the photographs.
  • 20 x 28 mm
  • 14 x 9 mm
  • 11 x 11 mm
