Assembling Zynthian Kit V5.1
Revision as of 20:58, 9 September 2024 by Jofemodo (talk | contribs)
Install the thermal block
Zynthian V5.1 gets a 25% extra power from the RPi5 by overclocking the CPU up to 3 GHz. For this to work properly, we need to remove the heat generated by the RPi5's components. As we don't want a noisy fan, prone to failure, pushing dust inside our nice case, we are using the aluminum case as a huge heat-sink. This is achieved by the thermal block, a solid aluminum block that closely contacts with the RPi5's chips and serves as a heat-highway to the aluminum case bottom, and from there, to the rest of the aluminum case. When your zynthian V5.1 is working hard, or when external temperature is high enough, you will note the aluminum case getting hot. This is good because it means the thermal block is doing its job of transferring heat from the inside to the aluminum case body, where it's dissipated to the ambient environment.
  • 20 x 28 mm
  • 19 x 12 mm => This is the most important one!
  • 14 x 9 mm
  • 11 x 11 mm
