Zynthian UI User's Guide - Oram
- Knob#4 is the select knob.
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
1st row: Health & Load | ||
- knob#1
- knob#2
- knob#3
- knob#4
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- knob#4
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- 4 x controller widgets, dynamically assigned to the 4 parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
Chain MIDI learning:
Global MIDI learning:
- knob#1 - knob#4
- knob#4
- knob#1 - knob#4
- knob#4
- SEL
- knob#4
- SEL to select/check option.
- knob#4
- SEL
- replace the processor
- remove the processor
- knob#3
- knob#4
- knob#4
- SEL
- rename the device
- knob#4
- SEL
- knob#4
- SEL
- Access Main Menu.
- The easy way
- The cool way
- knob#4
- knob#3
- knob#2
- knob#1
- REC
- F4 adds a new empty loop
10 Software Version
10.1 Stable (oram-2506)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
